#1 |
Member
Vehicle(s): 77 comet 4dr, 289 / 76 maverick 2dr 250
Stale Gas in Tank?
Hello,
I have both a 77 comet and a 76 maverick. My maverick has been sitting in my garage since 1997. I pulled the engine for some work and other projects got in the way of the Mav. My problem is I left about 1/2 tank of gas in the tank. I put in fuel stabilizer, but it was probably too late, about 2 Years ago. I don't think the gas is jelled, and it was stored in a heated garage, so the eastern Canadian climate shouldn't have caused too much condensation. Iwas thinking of draining the tank by pumping it out as much as possible and diluting the remainder with fresh gas. Is this reasonable or should I drain it properly by dropping the tank and inspecting the inside of the tank as close as possible? Thanks for any replies. |
| Sponsored Links |
#2 |
Growing older but not up!
Smell it, if it smells OK, it will probably work. I have started cars that sat for 10 years and had no problems.
__________________
![]() "Todays racing technology has diminished the role of the driver way too much. Back in the days of 4 speeds, the driver had a lot more to do with the outcome of the race, and I can't imagine anything being more fun than that." Ronnie Sox |
#3 |
MCCI Member & MMB Member
77 Comet
What you could do is unhook the rubber hose at the tank and drain it as much as possible and blow if any gas backwards out of the line torwards the tank where it is unhooked. When the engine is back in, put strickly Water Remover (available at any parts store) in the tank and fill it up. This should do the trick. The only other thing is the carburator will be all varnished up if the gas was left in it, and it will need rebuilt for it to run good
__________________
Willie 75 Maverick Grabber (Still Original)Yellow&Black 76 Maverick Stallion (Still Original)Yellow&Black 76 Maverick Stallion (Bad Shape)Silver&Black 70 Mustang Mach I (Needs Restored)Yellow&Black 94 Taurus SHO(Opal Frost)ATX 99 Taurus SHO(Silver Frost) |
#4 |
I build t5's
Vehicle(s): 1972 2 door 302 maverick, 1986 5.0 stang gt convertible,66 mustang coupe, HEMI ram
I too have run cars that have been sitting for some time, your are likely ok.
Fire it up, see how it runs. Make sure you put in a bottle of moisture remover
__________________
Jeremy -1972 302 2 dr mav-going in:5.0 roller/gt40 heads/explorer (gt40)efi setup -1966 Mustang coupe 5.0 ford racing crate motor, gt40 aluminum heads, b cam, duraspark elec ignit, t5 with pro 5.0 shifter, 8.8 coming soon -1970 maverick grabber. bone stock. Was a parts car, till I fixed the damage. |
#5 |
Member
Thanks for all the tips. Good Ideas on blowing out the line and using moisture reducer. I smelled the gas, it doesn't smell to bad. I do know the odour of very bad( old) gas. Also, I would expect to rebuild the carb after sitting that long.
Interested in this thread? Receive email updates and post your own response by registering today, it's free! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| gas filter clogged? oil is gas tank!!! | duster70 | Technical | 9 | 2009-01-02 09:00 |
| Empty Gas Tank | Jean Doll | Technical | 11 | 2008-06-14 22:22 |
| 1970 Ford Maverick Gas Tank For Sale | Craig Selvey | Maverick and Comet Cars/Parts For Sale | 9 | 2007-09-24 18:07 |
| Another "?" from the Swede, gas tank? | Swede | Technical | 6 | 2004-08-10 16:55 |
| Gas Tank or ???? | jeremy | Technical | 3 | 2002-12-20 13:15 |
