Need gas tank for 72 Mav sedan
Discussion in 'Parts Interchange' started by Urban D Kaye, Mar 12, 2008.
  1. Urban D Kaye
    Urban D Kaye Member
    PA
    1972 Maverick 4-door
    Just thought I'd put this out there... my mechanic and I have been scrounging for an old, rebuilt, or repro gas tank for my rusty 72 Maverick 4-door. So far no luck. Any thoughts?
  2. freefli
    freefli Member
    77 mav 200 3 on tree
    freefli
    I just replaced one in a 77 2dr maverick with a 19.2 gal one from a 76-78 Granada/exact replacement. $53.50 junkyard price sure beat $120.00 plus advance auto price.good luck and happy hunting.
  3. Dave B
    75-77 tanks are available new,or you can use a Mustang tank, do a search, you'll find the info.
  4. Urban D Kaye
    Urban D Kaye Member
    PA
    People keep telling me that a 75-77 tank isn't compatible with my 72, so I hesitate to lay out the $150 or so to find out if they're right.
    Will ask around about the Granada tank as a substitute. Thanks.
  5. 71gold
    ..got one in my '73...same tank as a '72...
    just need the longer straps...:Handshake
    ...Frank...:bouncy:
  6. Dave B
  7. Urban D Kaye
    Urban D Kaye Member
    PA
    Got that, but what'll it take to make that tank fit my '72?
    Is it just a matter of longer straps, as Frank said?
  8. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Be aware of doing any dealings with "mattmeier" a novice member.:banghead: of this board. I bought a tank from him, yet he fails to give a status report. :cussing:Not a good way of doing business :mad:
  9. Dave B
    The longer straps make it easier, but when I bought my 73 it already have the 75 tank on it, and they used the 73 straps, just with longer bolts.
  10. j miller
    Polson, Mt
    i have a 71 tank i would sell if you are interested. came out of a 4 door . you just need to replace the filler pipe. tank is rust free. had it on my 71 that burned up.send me a p.m. if interested.
  11. Urban D Kaye
    Urban D Kaye Member
    PA
    j- Sent you a p.m. Check yr in box.
  12. squito
    squito New Member
    st.louis mo
    1972 maverick
    tanks
    i bought a new f-30 model number from the parts store. you need the longer straps that go with it. its made for a 76 but it fits right up. the sending unit can be replaced but i used the old one. you dont reall know whats going on with the first 4 gallons but after that it works fine. the only thing is if you buy new you cant get a new vent for the tank, however take the old vent and modify it. there are three nubs grind those down and weld it right on.
  13. Urban D Kaye
    Urban D Kaye Member
    PA
    squito -
    Thanks. Actually located a tank from a 71 from another forum member. Due to arrive any day now. -Charlie
  14. Urban D Kaye
    Urban D Kaye Member
    PA
    Quick update... my 72 is up and running after receiving her replacement tank (thanks Jason), sending unit, (courtesy of eBay), and carb & choke linkage.
    Had her out today for a run in the sun.
  15. j miller
    Polson, Mt
    glad it worked out. congrats!
