Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2004-07-19, 19:53   #1
Grabber5.0
Gear-head wannabe
Grabber5.0's Avatar
Vehicle(s): 71 Grabber
Images: 21
C4 big bell/small bell differences
I discovered this recently when switching from a big bell to a small bell C4, and wondered if anybody else has encountered this. The big bellhousing doesn't just have the starter moved over to accomodate the larger flexplate. It's also about 5/16" deeper than the small bellhousing. The torque converter is also the same hair longer.
I had a stall converter made up for my new engine, and got my old tranny rebuilt and had the bell from a 74 Maverick put on it. When I finally got everything bolted together, the motor would not turn so I could put the last three converter bolts on. I double, triple, etc. checked that the converter was seated all the way in the transmission. I checked the converter in my current tranny, and it 1" back from the front edge of the bellhousing. When I seated the stall converter in the same tranny, with the big bell, it also sat back 1" from the bellhousing. The stall converter only sat 3/4" back from the front edge of the small bellhousing on the new tranny. With only 3/4" spacing, by the time the bellhousing drew up to the block, there was too much pressure on everything for me to rotate the crank with my ratchet.
I have searched and searched, and found virtually nothing on this subject on the net. I did run across one tech site that mentioned it, and another site for some guy that sells converters. That site listed a bunch of different part#'s for the various incarnations of the C4 bellhousing from various years, along with some specs, including the depths. There were at least 5 or 6 different depths! I am sure there is some leeway in the tolerances, but how could you ever get the right converter if you were ordering one?!! Here is the link to that site: http://mmerlinn.bravehost.com/trans/fdc4f/Fd9c4bhd.htm
__________________
Matt Williams
'71 Grabber 5.0
Grabber5.0 is offline   Reply With Quote
Sponsored Links
Old 2004-07-19, 20:59   #2
dmhines
Dixie Maverick Boy
dmhines's Avatar
Vehicle(s): 1971 Grabber / 2012 Mustang / 2009 Jeep Wrangler / 2013 Ducati / 2009 Buell XB12Scg
Images: 8
I had a 73 that was originally a 3 on the tree and I converted it to a C4. I have no idea what the tranny was out of ... I just picked it up at a transmission shop. I ordered a torque converter from GER and installed it. Even with it properly seated I couldn't even get the bell housing to meet the block. Returned to GER and they sent a different one ... still had a problem fitting it. I finally talked to a tech guy at GER and explained what was going on ... he figured out what I needed and sent the correct converter and it went right in. Sorry I have no part numbers or anything like that but had a similar experience a long time ago ...
__________________
dmhines is offline   Reply With Quote
Old 2004-07-19, 21:21   #3
Grabber5.0
Gear-head wannabe
Grabber5.0's Avatar
Images: 21
I meant to say that I was taking my converter back to the shop that built it so they can fix it. Apparently they looked it up wrong before, but now they know what I need.
__________________
Matt Williams
'71 Grabber 5.0
Old 2004-07-19, 22:46   #4
don graham
Senior Member
don graham's Avatar
Vehicle(s): 70 mav, 71 grabber, 73 mav, 73 Comet, 2004 f-250 crew cab diesel, 98 taurus, 2001 montana
Images: 12
when you order the convertor from a catalog such as summit, they list the years of the tranny plus the size of the flex plate. my original one was for a big bellhousing. when i switched to the smaller bellhousing i had to order another. in 1970 they changed from a 24 to a 26 spline input shaft in the tranny. when i changed to a 74 c-4 i again had to order another convertor. it all depends on the year of the tranny.
__________________
don graham q751
don graham is offline   Reply With Quote
Old 2004-07-20, 21:22   #5
MavKatrina
Member
Thought this might help....
http://www.mustangcentral.net/tech/c4.html
http://www.tciauto.com/tech_info/c4_bellhousings.htm
*going through same issue...found these sites helpful*
MavKatrina is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Small Bumper to Big Bumper & back? MikeG747 General Maverick/Comet 10 2006-08-12 20:54
Goodrich, Firestone, Big O rosalindr Wheels and Tires 55 2006-08-10 13:19
Big Block building brainsboy Technical 3 2006-05-25 14:20
WANTED: JW Ultra Bell for SB Ford / C4 157 Tooth Rick Book Maverick/Comet Cars/Parts Wanted 0 2005-09-19 11:08
Need small bell C4 engine plate! Grabber5.0 Maverick/Comet Cars/Parts Wanted 7 2004-07-16 21:38
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
