351W harmonic balancer and flexplate question
Discussion in 'Technical' started by MP1966, May 26, 2008.
  1. MP1966
    MP1966 Member
    OKC
    72 comet
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    you better just get 28oz balence damper and flexplate
    i dont know which 302s had 50oz imbalence
    some one on here does though(y)
  3. scooper77515
    Be sure it has the correct number of bolts, is the same imbalance as the flexplate and that the imbalance matches the crank imbalance, and if you just spend a little more, you can get a high performance balancer that will likely be up to the task of a higher spinning engine.
    I just bought this one 50 oz imbalance for my 5.0, only $70 off ebay...http://www.fastpts.com/cgi-bin/hazel-cgi/hazel.cgi?action=serve&item=ppdampers.html
  4. don graham
    What year is the engine? The 302 and the 351w?:)
  5. baddad457
    Being that it's a 3 bolt balancer, it should be correct for a 351. BUT.......... also being a 3 bolt, your 4 bolt crank pulley isn't going to work
  6. bmcdaniel
    All 351Ws are 28 oz imbalance, same as 302s up to about 1981. The 3-bolt and 4-bolt pulleys share the same bolt circle diameter, one of the pullley holes will align with a damper bolt hole, then just drill two more holes in the pulley where you need them.
  7. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    as far as I know Ford went to a 4 blot pully in 68 for all W engines. Every 351W I have seen has a 4 bolt pully. Cant say about the 351C engines. All 351Ws have a 28oz imballance so if you are using pre 1980 302 stuff you will be OK.
  8. PaulS
    Ineed a four bolt pulley for a 351W...... anyone have one to get rid of?
  9. baddad457
    Pretty sure I have at least one three sheeve 351W pulley left. I'll have to check later this afternoon though. Same pulleys used on the 351C & 400's.
  10. Fordmaster169
    Coos Bay, Oregon
    I have got a used Fluidamper w/28oz Ballance and 4 bolt pully mounting that I would sell for $150 + shipping.
  11. MP1966
    MP1966 Member
    OKC
    72 comet
    Thanks guys...
    The new 351W is speced for a 69-74 model years. It has D00E casting heads and is between 8.0 and 8.5:1 compression ratio according to the builder. My dad will get in touch with the rebuilder to see what they recommend.
  12. bmcdaniel
    Could just get a Professional Products damper for $75. They come drilled for 3- & 4-bolt pulleys and use removeable counterweights to get 0, 28 oz, or 50 oz imbalance.
  13. PaulS
    That is kool but I only need the pulley with four holes to mount it to the existing dampener.
