370c.i. 302stroker - 600HP on pump gas
Discussion in 'General Maverick/Comet' started by Fish OutOfWater, Jan 3, 2008.
  1. Fish OutOfWater
    Fish OutOfWater Brian
    Long Island, NY
    [​IMG] [​IMG] price: US $9,800.00
    AS SEEN IN NOV 06 ISSUE OF MUSCLE MUSTANGS & FAST FORDS MAGAZINE
    EXTREME PUMP GAS
    SBF 370 STROKER
    All Forged Internals housed In a Dart Block
    T and L Engine Development stuffs over 25 years of NASCAR experience and success under your hood. We are a NASCAR race engine facility that has recently developed a variety of custom stroker engines for your street vehicle. Each engine is DYNO TESTED and backed by a 12 MONTH, 12,000 MILE WARRANTY. View our [FONT=Arial,sans-serif]SHOP TOUR[/FONT]to get an insiders view of our facility including machine shop, assembly rooms, and dyno rooms with each picture featuring an informative caption.
    Ford 370 A-1 600 HP ON PUMP GAS 3.400 4340 forged crankshaft
    • 4340 5.400 H-beam rods
    • Forged pistons
    • Moly file fit rings
    • Dart block
    • Dura-bond cam bearings
    • Block plug kit
    • New oil filter adapter
    • T&L custom grind roller camshaft
    • Fuel pump eccentric
    • Roller timing setup
    • Custom gasket set
    • Aluminum front cover
    • Professional products balancer
    • Balancer bolt
    • Melling high volume oil pump
    • Melling oil pump drive shaft
    • Melling oil pump pickup
    • Roller lifters
    • Dart or Edelbrock aluminum heads
    • 7/16 screw in rocker studs
    • Comp push rod
    • Jesel Shaft roller rockers
    • Edelbrock Victor Jr. manifold
    • ARP head bolts
    • Chrome valve covers
    • Chrome oil pan
    • Autolite spark plugs
    • Oil filter
    • New 12pt bolt kit
    This engine comes with a MSD distributor, Custom fit Moroso wires and a AED Custom Carburetor.
    Labor
    • All parts hand cleaned
    • Block sonic checked for thickness
    • Block pressure tested @40 psi
    • Block stroker clearanced
    • Block square decked w/BHJ fixturing
    • Aligned hone mains
    • Bored and honed w/torque plates
    • All clearances checked to the nearest .0001”
    • Rotating assembly balanced
    • Engine blueprinted w/specs sheet on file
    • Engine fully assembled and dressed to customer specifications
    • Dyno tested
    Labor will also include FULLY Ported heads and manifold package.
  2. don graham
    only $10k. heck, buy me 2.:)
  3. Fish OutOfWater
    Long Island, NY
    scooper, that would be like 285 - 290 RWHP
  4. 19BlacK77
    19BlacK77 Member
    There is a guy near me that has a great motor for sale and He's asking $3,500 and its well worth the money. If anyone is interested on it heres the specs:
    74 D-4 Block
    Steel Crank
    385 stroke
    Coast High performance track dominator kit(forged rods and pistons)
    4.060 bore
    Comp Cam Hydrolic Roller Cam
    Comp Cam Roller Rockers
    Victor Jr heads and intake
    Milling Oil Pump
    Aliminum Value Covers
    Comp Cam T-Bars hydrolic lifters
    ARP oil shaft
    Miden oil pan and pick up tube
    11:1 compression
    http://i153.photobucket.com/albums/s239/brianuk21/100_0119.jpg
    http://i153.photobucket.com/albums/s239/brianuk21/Jayden121.jpg
    A well known guy out of London, Ky built it and said that it should be putting down 550 hp on motor alone. :yup:
  5. wagesofsin
    wagesofsin Official Lurkologist
    sarasota, florida
    74 challenger , 73 'cuda , 72 challenger , 74 barracuda
    i built a 362 that has 575, and it cost me 9800.00 2 years ago. now i feel ripped.
  6. 71gold
    i highlited in orange what thought to be ...non HP parts.
  7. Jamie Miles
    Alto, GA
    I've had a few
    I guess it would be a great deal if you had 10 grand burning a hole in your pocket...
  8. mean_maverick
    I thnk it's a pretty good deal for someone that doesn't want to build one
  9. FredH
    FredH Member
    Seminole, FL
    69.5 Maverick
    Gives you a reason to spend all that Christmas money you got! :yahoo:
