Anyone use Dielectric grease on spark plugs?
Discussion in 'General Maverick/Comet' started by mrcomet, Feb 2, 2009.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Has anyone used dielectric grease on you plugs to make the boot go on easier? Any comments or concerns..................
  2. Mavman72
    Yup...no ill effects yet...been doing it for 20 yrs.
  3. Blown 5.0
    MS.
    1974 Maverick
    +1 Always do if i want to remove the wires at a later date.
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I use it on the wires at both ends, distributor and plugs.
    Also, use anti-seize on the plug threads. The silver type works fine.
    That is a MUST on aluminum heads, but is also good on iron heads.
  5. Joe Dirt
    Makes it a ton easier to remove the wires later.
  6. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    I always use it, thoughh I've been told to try not to get too much on the leads.
  7. coutangman
    coutangman Member
    Charlotte, NC
    I use it each time I change plugs or wires. I buy it by the can with a special nozzle that fits down into the plug wire ends. It keeps the wire from sticking to the plugs, lowers the possibilty of moisture build up, and helps conductivity.
    We have people come in all the time wanting one plug wire because they broke it taking the wire off the plug. They did not use the grease. I recommend it with all sales of plugs and wires at work. It is also used for reducing sqeaking in brakes, holds down corrosion on battery posts, and should be put on all light bulb connections for the same reasons.
    Great stuff!
    Jim
  8. darren
    We use it depending on application. Di-electric grease is a great insulator. It seals up the wires and helps keep good contact. We have issues with it on some engines with plug tubes. The HEMI for instance gets so hot in the plug tubes the grease burns to a thick brown film that damages the coil ends. We have been told not to use it on the spark plug tube type engines. I go through a jar every few weeks at work. I use it on a lot of connectors. Just dont put it on an O2 connector. They need to bring in fresh O2 through the wiring and it will fail. Lots of guys get burned on that one.
  9. hacksaw415
    hacksaw415 Member
    slum bum frisco
    75 booger green mav
    dont use it on the sparky end.... i use it every time.
  10. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    This is something I've wondered about. Isn't dielectric grease a CONDUCTOR, not an insulator? So, when you put in a spark plug boot, aren't you putting a conductor between the top of the plug (connector) and the grouded spark plug body? I know people use it but I don't understand why its not a problem. Can someone explain it?
