Broke vacuum connector...
Discussion in 'Technical' started by A_Bartle, May 4, 2015.
  1. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    So took my Maverick out last week, noticed the brakes were spongy, so I decided to take a look at the rear first. Found out the wheel cylinders are leaking, so time to replace. Since I need to do that, I decided to install the power brake booster I purchased a couple years ago, and just never found the time to get it done (see this thread http://mmb.maverick.to/threads/adding-power-brakes-to-a-1974-comet.36934/ which was named: Adding Power Brakes to a 1974 Comet). I bought the booster that Nightshades recommended from
    http://www.abspowerbrake.com/.
    This is a '76 Maverick with a 200 I-6 engine. First thing I was "trying" to do was remove the end plug (yellow arrow) in the vacuum connector so I could buy a fitting to attach a hose that will run to the new booster. I put a 5/8" socket on the bolt and turned it just a little bit, and "pop" I saw I broke the connector (red arrow). It must be white metal or something soft, because I didn't put much pressure on it at all.
    So, is this part even available as a replacement, or is there an alternate way to do this (I believe there are 3 other small hoses that need to be attached)??? How do I go about fixing this mess? I'm guessing I'll be able to use an easy out to get the broken threaded part out (hopefully). It's one of those nights when I should have stayed in the house and went to bed!
  2. Craig Selvey
    Yep....you should have held the part with an end wrench while you tried to remove the plug.
    This is a standard part on all 6 cyl cars so you should be able to find one. Yes...an easy out will get out the rest.
    There is a mini-meet in Dearborn, Michigan at the end of the month....maybe I will see you there.
  3. 71gold
    soak it in PB blaster...:thumbs2:
  4. Rasit
    Rasit Member
    SE Pennsylvania
    Google "ford vacuum tree" for lots of alternatives.
  5. A_Bartle
    Michigan's Thumb
    Thanks guys for the quick replies. I had no idea that part was so fragile (lesson learned). Anybody know what the size and threads of that opening will be? Would be great if I can get something on order before I have a chance to remove the broken part.
  6. 71gold
    are these vac. ports removable?
  7. 71gold
    I may have one...I can check here shortly...how many ports on the tree?
  8. 71gold
    Im back...I have one, shoot me a ship to address and it's yours...:thumbs2:
  9. A_Bartle
    Michigan's Thumb
    Wow, that would be awesome, thank you very much.
    Art Bartle
    Paramount Ind. Inc.
    304 N. Howard St.
    Croswell, MI 48422
    I hope I don't have too much trouble getting the broken piece removed. Might try that "freeze & release" stuff I've heard about.
  10. A_Bartle
    Michigan's Thumb
    Frank,
    It was getting late last night, but before I went to bed I happen to check this thread, and saw your note to "soak it in PB blaster". I actually put my shoes back on and went to the shed and sprayed it down. I'll hit it a couple more times b4 I try removing the broken piece. Just now wondering if I have an easy out that large, if not time to add to my tool collection....
  11. A_Bartle
    Michigan's Thumb
    I was just looking at my photo close up and I wondered about getting the "new" part on. It "looks" as if to screw it on, the exhaust manifold will be in the way (because the vacuum tree is a long rectangle)? Not sure until I actually get in there, but that's how it looks in the photo. Anybody know if that true, because I don't want to remove the exhaust manifold!
  12. Craig Selvey
    Yes it is (as you probably found out). :D
  13. 71gold
    on the way...:outtahere:
  14. A_Bartle
    Michigan's Thumb
    Thank you, much appreciated!!
    Did you have to remove the tree from the intake manifold? When I re-install it, will I have any problems threading it in without hitting the exhaust manifold?
  15. 71gold
    it was already off...
    sending PM with tracking #...
