Coating or painting Bolts
Discussion in 'General Maverick/Comet' started by zorares, Mar 12, 2013.
  1. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    What is the best way to treat or paint bolts to help prevent future rusting and corrosion?
  2. bmcdaniel
    Paint the tops with Rustoleum, dip the threads in Milk of Magnesia. Depending where they're used you could just buy stainless steel fasteners.
  3. Mavman72
    Some form of plating is preferred to paint on bolts, since a plating or phosphate coating will resist chipping more readily than paint...If you have to paint, try and get some socket liners that prevent chipping the paint during install.
  4. mojo
    Where wud u most likely not use the bolts dipped in MM?
  5. mojo
    Where wud u get socket liners? I don't recall ever seeing any?
  6. Craig Selvey
    All of my brand new bolts were clear coated with Diamond Clear from Eastwood.
  7. predfan2001
    I soak them in a jar of vinegar to remove rust (some times wire wheel) and coat them with Rustoleum flat black.
  8. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Last time I got some stuff zinc-chromated (that pale gold look) was over 30 years ago and over $100 then for a handful of small pieces that would fit in a small USPS flatrate box. My bud uses Dupont epoxy primer for durability, then tops it with Rustoleum for color.
  9. groberts101
    groberts101 Member
    Minneapolis, MN
    I've had painted bolts hold up for more than 10 years with only slight losses in gloss from time/heat.
    Paint holds up just fine if you are sure to clean/prep them well enough before coating. Proper curing before assembly is also critical to avoiding heavy chipping when reinstalling. Even if you do get a boo boo at assembly.. touching up with a modeling brush will keep it from further chipping/corroding.
  10. darren
  11. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    As always, much good information. Thanks all!:clap:
  12. rthomas771
  13. 71gold
  14. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
