Engine cut-off whule driving
Discussion in 'Technical' started by mrcomet, Dec 12, 2009.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Hi Guys,
    Took the Comet out for a spin today. Got about 5 miles down the road and the engine cut-off. Was just doing normal driving when it happened. Pulled over and tried to restart. The engine turned over fine but it was hard to start. Had to pump the pedal a lot. It ran for about 30 seconds then cut-off again. Popped the hood, everthing looked fine. After about 5 minutes I tried to start it again. It took some pedal pumping but it did start and contiuned to run. Drove home fine the whole way. No sputters or any indication of engine issues.
    Had the car for over 2 years now. This is the first time anyting like this happened. It has a new Holley 4b (1 year on the car) and the engine and all the fixins are only 3 years old. Car has been running great all this time.The only thing we did different was an extreme burnout last weekend.
    I think its either a fuel or electrical issue. Can you give me a checklist of things to go thru to trouble shoot. I have a few ideas but I don't want to miss anyting that could be an easy solution.
    Thanks!!
  2. Bryant
    what tpye of ignition system do you have?
    that really sounds like an overheating ignition moduel. thats hard to test. the only way that i can think of to test it is to get it to die again then check to see if it it has spark right away.
  3. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    I'm using a Blaster 3 coil. It's only 6 months old.
  4. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    Did you change the fuel filter? I'd try that first. Even if you didn't change it that long ago.
  5. rthomas771
    My car did the same thing. It was the starter solenoid
  6. apotter80
    apotter80 Member
    charlotte, MI
    1971 maverick grabber(CLONE)
    My car did that too. believe it or not it ended up being the ignition switch down on the column was shorting out. so it was like i was turning the key off intermittently. I also replaced the starter solenoid first which got me no where. good luck!:tiphat:
  7. Bryant
    what type of distrubtor do you have? points, duraspark, aftermarket eletronic.
    do you have an ignition box of some type? msd, mallory, duraspark, etc.
  8. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    my car is doing the same thing and i have switched over to ignitor II system and i have to get a new fuel sending unit since my fuel gauge doesnt work but im hoping this will fix it
  9. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    I have a point-less distributor. All new wires and plugs. No ignition box.
    Think it would be good to change the cap and rotor?
  10. Bryant
    no cap and rotor should have nothing to do with it cuting out. what type of eletronic distrubtor are you running. thats my number one suspect that would cause your problem.
  11. brainsboy
    brainsboy Member
    Tampa
    I had the same exact problem! clogged fuel filter
    Take off the aircleaner and look down the carb, move the throttle a few times and see if fuel is squirting.
  12. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    I put a new ignition coil on AND replaced the fuel filter. Took it out and it did it again. Could it be the fuel pump has low pressure?
  13. apotter80
    apotter80 Member
    charlotte, MI
    check that ignition switch out yet?:huh: took care of my problem
  14. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    No - what's the best way to check it?
  15. apotter80
    apotter80 Member
    charlotte, MI
    best to just replace it. i think mine was around $20 for brand new one at auto parts. but it solved my problem. may not be your case but i would try it.(y)
