Fluid level for Ford 8" rear end
Discussion in 'Technical' started by mrcomet, Aug 1, 2010.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    How much fluid is the proper amount for a Ford 8" rear end. I have a leak and need to know how much to put back in after fixing.
    Thanks!!
  2. Acornridgeman
    Wisconsin
    With the axle level, put it in slowly until it starts to run out of the filler hole. Bottom of that hole is the full level.
    (y)
  3. don graham
    Yep. What Eric said. Have a rag handy.:)
  4. 302-72-mav
    302-72-mav Member
    sactown CA
    some third members do not have a fill whole the last 2 that i broke didn't have one
    so i had to fill it up by pulling one of the axles and having the car at a slight angle to put the fluids in it i think i put 3/4 of it in out of 1 gallon
  5. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    That makes sense.............Thanks for the info!!!:thumbs2:
  6. sgaugeguy
    sgaugeguy Bob Kraus
    WILLIAMSTOWN NJ
    72 Ford Shop manual calls for 4 pints. Then the sub note reads : "Approximate refill capacity - Actual lubricant capacities are determined by filling to 3/8 inch below filling plug hole". How would that be measured?
  7. Awesome_X
    Awesome_X Member
    Oklahoma
    When I worked at the tire and lube joint I was told to stick my pinky finger in the fill hole and if it can touch the fluid then it was full and if not then add some until I could touch or it was at the bottom of the fill hole.:huh:
  8. Stavro
    Petaluma, California
    1972 GRABBER ZRX1200r
    When it actually has a fill plug (I've yet to ever see one without one but they obviously exist) I fill it till it pours out....cap it..........let it settle for 15 minutes or so and check and fill it again.
  9. Acornridgeman
    Wisconsin
    I have never run across one without a fill plug. Makes you wonder how they filled those at the factory ............... :huh:
  10. rthomas771
    Through the fill hole on the side of the case.
  11. Bryant
    The early 8" didn't have the fill plug in the case. It was in the back of the housing.
  12. Craig Selvey
    Correct. Combine that with a newer housing and guess what? No way to fill it. :D
    P.S. Unless you want to pull out an axle and fill it down the axle tube.
  13. sgaugeguy
    sgaugeguy Bob Kraus
    WILLIAMSTOWN NJ
    How about this idea? If there is no filler plug anywhere, unscrew the vent tube holding down the rear brake hose and fill it through that hole. As long as you know the capacity it should be fine.
  14. simple man
    simple man Member
    Bunnell,Florida
    WOW! that's a new one to me! Mines on the left side of the third member. I guess some models had the fill in the back of the housing,so their third member wouldn't have a fill. :hmmm:
  15. Acornridgeman
    Wisconsin
    I never had one like that .......... very interesting. (y)
