Fluidampr and crank pulley compatibilty
Discussion in 'Technical' started by Jory, May 16, 2013.
  1. Jory
    Jory Member
    Greenville, Texas
    1971 Ford Maverick 4-door
    Hey guys, quick question. I have a chance to buy a very lightly used Fluidampr balancer (28oz.) for $60 and I was curious if I would need any spacers and/or adaptors for the stock crank pulley (4 hole / 3 groove for alternator, PS, water pump, fan, AC) D0OE-6312-C.
    My balancer has some cracking around the rubber spacer and with the vibration I've been having, I don't think it would be a bad investment.
    Edit: The Fluidampr spec sheet doesn't indicate that I need anything like a spacer or adapter...looks like it might be ok.
  2. Bryant
    it should work for you. i dont think fluid dampener needs a spacer.
  3. bmcdaniel
    Be aware that some engine builders recommend against using a Fluidamper on a low rpm street engine. They feel the fluid doesn't react quickly enough to the constant rpm changes of a street engine. I've never used one so this isn't from my personal experience.
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    it will.. and it doesn't.
    if it's good enough for multi-million dollar industrial equipment?.. then it's good enough for the junk I usually run. :)
  5. Dave B
    My Fluidamper, needed a spacer.
  6. Jory
    Jory Member
    Greenville, Texas
    What motor and what pulley are you running with yours? What spacer did you use?
  7. Jory
    Jory Member
    Greenville, Texas
    Are our balancers pressed on? Do I need a tool to remove my old one? Any tips/tricks up anyones sleeves that I could use so I don't have to rent a tool? Thanks!
  8. mercgt73
    1. Yes.
    2. Yes. You need to use a balancer puller.
    3. I have never removed a balancer without a balancer puller. I have installed a balancer without a balancer installer, though.
