grille lights
Discussion in 'Technical' started by mywifeisawesome, Jun 19, 2016.
  1. mywifeisawesome
    mywifeisawesome Member
    Pittsburgh, Pa
    1973 Mercury Comet
    Hi everyone. I'm trying to fix my marker lights in my grille of my 1973 Mercury Comet. I removed the wiring from the light housings. Are the sockets removable? I see autokrafters sells new wiring with a socket but they look to be only two wire? Mine are three because they have a ground that connects to the socket itself. Would these work anyways? Also how do you remove the original sockets from the light housing? Thank you.
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Post a photo of yours, that may help us to see what yours look like. My 72 Comet on has 2 wires.
  3. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    I will. Do you know it the socket the bulb sets in is removable? Seems like they're really in there.
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    With enough force you can remove the sockets, but they are not supposed to be removable from the buckets.
  5. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    I wonder how you're supposed to replace them then? Maybe I can find just the plastic inner pieces and wiring. I'm also wondering on mine it only has a ground wire on the driver side grille light.
  6. jasonwthompson
    Carrollton TX
    They were made as an assembly, the bucket, socket, and connector. Outside of replacing the bucket assembly, I do not think Ford made them to be serviceable. If you are handy with a dremel tool you could remove the socket from the bucket and possibly slot the bucket to accept a twist in type socket or a push in similar to the brake lights.
  7. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Wonder if grille lights from 70 mach 1 will work? Look the same?
  8. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    I think I have an extra set of three wire lamps.
  9. Craig Selvey
    Plug on the harness is different.
  10. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Hi. You selling them? In good shape?
