Head Light Relay Update
Discussion in 'Technical' started by mavdog71, Apr 5, 2009.
  1. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Well I went an dun did it installed the relays what a differance. Did some voltage numbers with the engine off 8.7 volts at the light with engine running at 1000 rpms 9.8 volt at the light on low beam these readings before installing the relays . Now after installing the relays on both low and high beam sides with the engine off 11.8 volt at the light on low beam with the running at 1000 rpms 14.2 volts at the light on low beam . Now I have light that will burn the ba$$ off a brass monkey ...
    I didn't run new wires to the light ( only a .02 voltage drop between light ) as shown in diagram in ford truck article but for only 30.00 dollars and 3 hrs work WELL worth it .
    Jay
  2. blugene
    I need the diagram :). Hopefuly it is simple :dizzy:
  3. rthomas771
    Now you will have to use your low beams when you pass the big reflective signs on the interstate at night or you will see blue spots floating around in front of you. Other than that you will enjoy seeing where you're going. This and delay wipers is one of the best upgrades I done on my Falcon. I will be doing the same on my Maverick soon.
  4. Joe Dirt
    id like to see the diagram myself
  5. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    Gene
    THE diagram I used is on the ford truck site but I didn't run new wires to the light. There is the one I used http//www.ford-trucks,com.article/idx/8/039/article/whiter_whites_brighter_brights.html
    I got two 30 amp bosch relays 1 for low beam 1 for high beam .
    terminal # 86 is ground
    terminal # 87 is to head light
    terminal # 30 is 12 volt fuse hot
    terminal # 85 is from the switch
    I mounted the relays on the radiator core support on the driver side near the d/s sport light . Remove the wire loom covering from the head light loom just inside of the core support . 1 Grounded the relays to head light grounding screw on the drivers side . 2 Terminal # 30 is 12 v 30 amp fuse hot to starter solnoid . 3 The low beam wire in the head light loom is red with a black strip cut that wire the light side of that wire goes to terminal # 87 the other side if that wire goes to terminal # 85. The low beam side is finished . For the high beam side repeat step 1&2 then find high beam wire LT green with a black strip cut that wire the light side of that wire goes to terminal # 87 on the high beam relay and the other side of that wire goes to terminal # 85 . The high beam side is finished .
    Jay
  6. blugene
    Ok, thanks. I will referr back here when I get to this stage. I bought some new xenon gas charged bulbs I wanta use. They will be kinda blu :D
  7. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    Gene
    Cool you going to look like one of does yuppie moble ( BMW BENZ LEXI )
  8. blugene
    Just trying to be classy ;)
  9. rayzorsharp
    :rofl2:
    :16suspect
    :hmmm:
    :cry:
    :scratchchin:
    :idea:
    :huh:
    Aww heck...I might as well do it too. :rolleyes:
  10. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Cool, i think i'l jump on the band wagon also. I bet there alot brighter huh.
  11. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    they arent the greatest in a snow storm...:rolleyes: wait who drives their maverick in the snow....:cry: but they work pretty good the rest of the time.
  12. mitch christens
    mitch christens Member
    Marion,iowa
    75 maverick, 2006 jaguar x type, 2004 ford f-150 super cab,
    You should write a tech article this is a mod alot of guys can do inexpensively and sounds pretty simple. Besides I'll know where to get it when we do our mav! Good job,great mod.
    Mitch
  13. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    Will draw up a diagrham this weekand will write a artical and post it this weekend..
    Jay
  14. blugene
    That would help ME out greatly. I love drawings :rofl2:
  15. 71gold
    Earl and i did this mod about 3 yrs. ago...
    when i had my new wiring installed we removed it...i should have kept it and someone else could have used it..
    we made a small wiring harness that pluged into the old headlight plugs and had new plugs for the lights.
    we were thinking that if anything happened to the relays, we could just plug the stock plugs back in...(y)
    ...Frank...:Handshake
