headers
Discussion in 'Technical' started by Unionmade, Dec 11, 2007.
  1. Unionmade
    Unionmade Member
    NONE
    Does anyone know of companies who make a 1 3/4 headers for a 71 mav. with a 302. second, will a x-303 cam work with stock flat-top pistons with out fly-cutting
  2. scooper77515
    The X-303 is smaller than what I am putting in mine, and I haven't encountered any problems yet with mine at .560 lift. Mine are flat top with valve reliefs.
  3. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    The general rule of thumb is Any time you exceed .500 lift it is a good idea to check the piston to valve clearance. I have an X-303 in my 308 with no problems even my thin (.025 thick) Cometic head gaskets but my pistons are Speed -Pros which have LARGE valve reliefs.
    On the other hand I`m in the middle of a heads,intake and cam swap on my sons 5.0 Mustang and we are using a cam with .498/.518 lift ...the heads are 1972 302 that have been milled once and trued up a time or two over the years and have had 1.94/1.60 valves installed. With a .042 (Fel-pro) gasket I only have .001 clearance on the intakes! You need a minimum of .080 int. and .100 exh. SO this weekend I will be fly-cutting the pistons.
    P.S. Frank told me he thought it would be ok to run it "as-is" because it would probably 'clearance" itself!:cry::idea:
  4. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    I bought a set of Hedman Hedders from a member here and they are designed just for our cars. Longtube and mean looking. I'll be installing them after the engine is re-gasketed since it is wet.
  5. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    What is the part number on those?
  6. PAINTANK
    1973 Comet 2 dr
  7. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    so did you go with the 88300's?
    I just picked up a set for a cool 50.00 off CL
  8. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    Question? why do you want 1-3/4" headers?
    Their too big for a 302 unless your making 500hp and winding 7000 rpm where there is a need for that kind of flow.
    We only use that size on a 500+hp 351 cu/in alky burning 8000 rpm dirt sprint car running 1/2 mile tracks.
  9. scooper77515
    Bluegrass...that looks like FUN!!!
