heat not so hot?
Discussion in 'Technical' started by random hero, Dec 19, 2009.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    ok so i put in a new heater core (old one was bad) put in a new t-stat(spring on the old one was broken) flushed the coolant system 3 times(with a professional flush machine from the dealer ship i work at) all the air is out of the system. but still when driving my heat does not get that hot, but inside my shop ideling it gets nice and hot. what could be the problem? should i put a small piece of cardboard? install an electric fan with a thermostatic switch? any other ideas guys? :tiphat:
  2. Mavman72
    Faulty T stat (stuck open) Heater controll valve stuck shut (if ac equipped) Bad water pump impeller (rusted off/loose on shaft)Plugged up heater core.Big giant radiator(too efficient/not likely) Air in heater core/cooling system. Blend door in heater box not opening.Lack of air getting into heater box(not likely unless your cowl is sealed off or full of junk) I am sure theres more but...Its late,brain shutting down.Good luck!!!
  3. 71gold
    why would you think this?
    my cowl is sealed off and i have no heat/AC problems...
    Frank
  4. Blown 5.0
    MS.
    1974 Maverick
    A non a/c system pulls air from the cowl, A a/c car can recirculate.
  5. Mavman72
    Frank, I have seen cowls/heater boxes soo full of...crud/nests that the blower couldnt circulate any air to push the heat into the car.I did also say it was not a likely scenario.(not likely unless your cowl is sealed off or full of junk)Easy enough to rule out...:D
  6. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Low water in the radiator is usually what does that to mine. Vacuum leak preventing the ducts from opening, valve on the heater line not opening. My first Comet required me to raise the hood and manually open the hose to let hot water into the core.
  7. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    id say if its ok idling in the shop then id want to know what the engine temp is going down the road.
  8. random hero
    hudson valley
    1972 maverick
    thats my guess. maybe because it's so colad out and the air naturally moving over the radiator(being that it's subfreezing) is cooling it down a lot. hence my cardboard question...lol. i never thought about my water pump being bad though. i flushed the cooling system soi much because it was BROWN but now it's fine.
  9. Mavman72
    Check your water pump...May hav a lack of impeller blades due to rust(reason the coolant was brown = rust)
