How Much is a Ford 8 inch posi worth?
Discussion in 'Technical' started by Corbin Johnson, Jan 18, 2004.
  1. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Pretty much what the subject says - how much is a nice, complete limited slip 8 inch center chunk worth? Thanks. I am in the market for one, and have an idea, but it's always nice to have input.
    -Corbin
  2. madmav74
    madmav74 Member
    north dakota
    74'maverick strip car
    locker
    I got mine off ebay a complete "chunck" with 3.80 gears and a trachtech gearless locker ready to drop in for $630 shipped. I thought that was a pretty good deal pricing the parts through summit it would have been at least $700
  3. courier11sec
    courier11sec Member
    Tucson, AZ
  4. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I saw a powertrax setup for 8 & 9" rears in Jegs for $435, but I'm cornfused... They are listed in a section titled 'Powertrax no-slip traction system', but some are listed as open, some as trac-loc. So is it or isn't it a posi? :confused: :confused:
  5. Scotty P
    Scotty P Member
    santa rosa, ca
    Corbin, I built mine with all new parts from Summitt. Used PowerTrac Locker, new gears, bearing etc... Total was less than $500 and I KNOW all the parts are new. Scotty
  6. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I got mine used for $150 about 13 years ago...It's in need of a rebuild now...Still works though...
  7. madmav74
    madmav74 Member
    north dakota
    BS
    Scotty P
    how did you build your rearend for $500 from summit
    when the powertrax locker is over $400
    and the cheapest set of gears is $164.50
    and thats with out bearings or seals!!
  8. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Maverick Matt, What that means is that a factory "open" had a different spider gear case than a factory "trac- loc" ,so when ordering the power trax ...they need to know whicch case you are working with in order to send you the correct unit to fit in it.
  9. Grabber5.0
    Kansas City, MO
    71 Grabber
    Thanks Mike! :cool:
  10. Scotty P
    Scotty P Member
    santa rosa, ca
    MadMav, read my post before saying BS! I said I built a LOCKER, part #pwt1810LR, not the differential you likely looked at for $429.00 I looked for my receits but they are in the garage. Ring/Pinion $165.00, bearing instal kit $89.00 (includes shims, gaskets, bearings etc) and the powertrax locker (lockright) was around $249.00 or so. Friend owed me a favor and did the install cheap. It adds up.
    This is a locking unit coml;ete with clicks around the corners! Why would I BS fellow Maverick owners? Scotty P
  11. John A Fasig
    John A Fasig Member
    over here now
    several plastic and tin
    POSI
    I was told you can make one real cheap with a welder and the knowhow. I don't have either one of those. I bought a 8inch 2 weeks ago with 4:62 mini spool for $150 on ebay.
    Thanks again Cometgt1974 man thats long ride to your house.
  12. madmav74
    madmav74 Member
    north dakota
    scotty
    Scotty,
    sorry I blew up:( I've never seen the locker you described in summits catalog, but I see its in there online cat for $299 I'f I would have seen it I would have done mine the same way. Although the one I have has been very good to me. It gets alot of abuse and performs well, also quiet around corners!!
  13. Scotty P
    Scotty P Member
    santa rosa, ca
    MadMav, No Sweat!!! :) Scotty
