How to install temp gauge ?
Discussion in 'Technical' started by Bioinfomatic, May 28, 2007.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    In my 77 Maverick it has no temperature light or gauge, I was wondering how do I install an after market gauge to the 4.1 engine?
  2. maverick75
    if i remember correctly
    in the back of the head(drivers side) you should see a sensor thats hooked up to a wire that runs to the instrument panel...when you buy an aftermarket gauges they come with a fitting(and adapters) that goes into there.
      File size:
      102.5 KB
      50
  3. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    What color is that wire? And why would I have a sensor and a wire going to my instrument panel if its not going to tell me if the motor is overheating.
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Take it to a professional, since you're not familiar enough with auto mechanics to perform the installation yourself...
  5. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    Just because I asked for the color of a wire ?
  6. maverick75
    on v8 it should be white with a red stripe i don't know if its the same for a 6cyl..i really don't know why the hook up to the panel mine had it i just took it off
    btw: here are the diagrams for a 77 mav they might help you out
    http://www.maverickcomet.com/Wiring/MavWiring/1977/1977MainMav.pdf
  7. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
  8. T.L.
    T.L. Banned
    Southern Colorado
    No. You asked how to install an after-market Temp gauge. There is not a wire that you connect it to. You would run all new wire to the sending unit (if it's an electric gauge) or you would run a mechanical temp sensor if it's a mechanical gauge. I'd do it for you if you were here, but since you're not, you need to find someone where you are to help you. It's hard to explain here to someone who's not familiar with these things...
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Usually a mechanical gauge comes with complete instructions and all needed hardware to hookup. The sending unit is located on the drivers side rear of the motor on a 250-6. I went out and looked. There are 2 in that vicinity, one is oil and is completely on the side of the motor, the temp one is actually on the back of the motor. This is a very very easy install. Have the autoparts store you are dealing with sell you a NEW sending unit that is mechanical.
    Dan
