... length/setting...
Discussion in 'Technical' started by 71gold, Mar 3, 2013.
  1. 71gold
    ...front sway bar end links...
    what is the length of the center spacers.
    someone have a setting for installing these.
    ...:Handshake...:outtahere:
  2. rthomas771
    Vehicle must be on level ground or service lift (NOT jacked up, NOT wheels hanging and NOT having the suspension unloaded). Wheels should support the vehicle or lift jacks should support the suspension as if the wheels are supporting it.
  3. scooper77515
    How is that adjusted?
  4. Dave B
    With a hacksaw.
  5. scooper77515
    Figured as much. Couldn't see any other way.
    Typically, shouldn't it be about the right height when you purchase it?
    Every one I have ever installed was correct upon installation.
  6. Craig Selvey
    I have never cut the center sleeve....just installed them as is.
  7. Joe Dirt
    Correct the bar always has to be level at ride height
  8. 71gold
    did you know there was an installed height...:huh:
  9. Craig Selvey
    I did not know that.
    But....if the rear end is jacked up, it would throw off the measurement as well.
  10. 71gold
    what difference would that make...:bouncy:
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    depending on how jacked up it is.. about 1 millemeter or so. :rofl2:
  12. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Compresses the front end more so than at ride height. You'd end up with shorter spacers than you need. The sway bar should be completely unloaded at ride height.
  13. 71gold
    :hmmm:...so if the rear is higher than the front, there is no need for a sway bar being it can't be set correctly...:huh:
  14. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    It should be mounted with the vehicle at its stattic ride hight. Just don tput a jack under the rear of your car and lift it up when putting a front sway bar on. This loads the front suspension more than it would be inder normal ride height.
