Lug Pattern & Size?
Discussion in 'Technical' started by Bioinfomatic, Jun 3, 2007.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    I wanna purchase a nice set of rims for my maverick but I don't know the size of the bolt circle is it 5 x 4-1/2" or 5 x 4-3/4" ? :huh:
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Ford = 5 x 4-1/2"
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    5 x 4-1/2" for Mavericks...
  4. don graham
    don't forget if you want to go with a wider tire to check the backspacing of the rims also.:)
  5. yellow75
    Tillamook Oregon
    And dont forget to get rims with center holer big enough to fit over spindle on front of disc brake car, you dont want to learn this leeson the hard way
  6. Bob Wiken
    Fayetteville, Arkansas
    I am off to the salvage yard to get wheels big enough to fit over my new disc brake conversion. Mean while my car is up on jackstands
  7. maverick75
    good luck, one time i found a mav with centerlines but i was all out of money:slap:
  8. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Mopars use the same bolt circle, so if your looking for used rims, check the classifieds for both fords and mopars.
    Edit- Stay away from early Darts, they use a goofy 5 on 4 1/4 bolt circle.
  9. yellow75
    Tillamook Oregon
    I run slicks on a set of Mopar rims they have a nice 4 1/2 backspace, tuck the wheels into the wells nicely
  10. Bob Wiken
    Ii was real lucky. I found 4 Shelby Cal. Aluminum rims. I got them and a rear view mirror for $85.
    YellowComet likes this.
  11. Bob Wiken
    Now I have to replace all the studs as the aluminum rims are much thicker than the steel ones. There is barely enough stud to get the nuts on
  12. Craig Selvey
    Are you sure the wheels don't require a shanked lug nut?
  13. Bob Wiken
    I thought about that at work. I willhave to check itout
