Need a tool for primeing engine oil
Discussion in 'Technical' started by mike75mav, Sep 18, 2005.
  1. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I have a 302 thats real close to being none. I'm about ready to prime the engine, but I cann't find the tool that you use to turn the oil pump. Does anybody know where I can get one. Thanks
  2. Scotty P
    Scotty P Member
    santa rosa, ca
    You can either use an old dizzy with a drill chucked to it. Or, Jegs and Summitt sell a tool for a few bucks..
  3. scooper77515
    I use 4 magnetic extensions for those screwdrivers that you can change the bits on. Put four in line, and put them on a drill, and let er rip. Cost me about a dollar at the local hardware store.
    Warning, I think there are two sizes of the screw, so make sure this one fits. I think it is 1/4".
    edit--I tested it and took a picture, it only took 3 to get down the distributor hole.
    Scott
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    That's a heckuva idea Scott! (y)
    reminder (to any reader) - use reverse drill
  5. Scotty P
    Scotty P Member
    santa rosa, ca
    Take the cam gear off first!! Thanks for the reminder Rick..
  6. Acornridgeman
    Wisconsin
    Don't you need to seal off the hole completely to get the lifter gallery to fill under pressure? I thought that is why an old distributor or that tool is needed. :huh:
  7. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i used an old 1/4 extension with a socket welded to it. would hate to have it come apart.
  8. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    I found some hex rod and chucked it into the old drill and voila!
  9. Rick Book
    Rick Book Member
    Thailand
    Hmmm..... You might have a point there. :hmmm:
    My (borrowed) homemade primer still has the o-ring on the old dizzy (and presumabley seals).
    I also used the hold-down tab for the distributor too - thinking it might try to jump off the hex if not held down.
  10. FredH
    FredH Member
    Seminole, FL
    69.5 Maverick
    No, you do not need to seal off the distributor hole to fill the lifter galley (thankfully that it is one of GM's "bright" ideas, not Ford's). All you need is something to turn the oil pump.
  11. Mavaholic
    even if you use those magnetic extensions, put them together and then spiral wrap them with electrical tape like a wire loom. Last thing you need to do is drop one in the pan.
  12. mike75mav
    mike75mav Member
    Bremerton, WA
    Hey thanks for the idea's. I'll give it a try.
  13. courier11sec
    courier11sec Member
    Tucson, AZ
    Me too.
  14. mavman
    mavman Member
    Arkansas
    1/4" drive 1/4" socket on a drill...spun backwards works fine. Usually cheaper if you already have one in the toolbox too (cheaper than buying a $50 priming tool..or buying a junkyard distributor). Just put a little tape around the socket and extension so the socket doesn't come off when you pull it back out. 5/16" on most any other Ford engines....including a 2.3 4 cylinder. Same principle...spin it with a drill.
  15. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Lifters and valvetrain are plenty tough to survive the first start up. It's the bearings you have to worry about. I've always just used a 1/4" drive extension with a socket. I permatex blue the socket on so it doesn't fall into the pan.
