New calipers on my 77 2dr
Discussion in 'Technical' started by demo913, Nov 15, 2012.
  1. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I just installed new calipers and pads and have a problem. I was not able to get the support spring installed. The key fit in really tight. I also have both outer pads rattling. I have not drove the car but the brakes feel fine. I can not seem to find a picture to se where the anti rattle clip goes. I read it goes on the back but that doesnt seem like it would help me much.
    Thanks
    Matt
  2. rthomas771
  3. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Anyway I try the spring it will not fit in. I have used my old one and the new one. Anyone ever run into this problem?
  4. Bryant
    you need to put the spring in at the same time as the retaining block. i will put the spring on the block then wedge it in-between the caliper and bracket then tap it in.
    as for the outer pad being loose, i usually will bend the tabs in so they are tighter on the caliper. it takes care of the click that they will have.
  5. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I have tried that method bryant and could only get the key to fit. I am pretty sure the caliper is in the right position. It is so tight that the key barely fits in but it does. Is this spring 100% needed. I did bend the tabs and put the rattle clip on the rear and cleared that annoyance up.
    Thanks
