New member
Discussion in 'New Members Forum' started by royster, Jun 18, 2015.
  1. royster
    royster New Member
    62,63 Fairlanes, 06 GTO, 02 Subaru WRX
    Just signed up as I;ve stumbled upon a very solid looking 71,72,73? Mav.grabber, the owners wife is not sure what year it is & is desperately looking for the ownership so I can purchase this 39,000 mile little Maverick.
    So, I haven't even looked under her yet, any areas I should look at for rust, damage, were based in the snow belt!
    Do the Mav's have tork boxes like my Fairlanes do?
    Any hints, or things to look for please do share, oh, its a V-8 I;m assuming a 302, stick car but can't get passed locked doors yet, assuming a 3 speed?
    Thanks for any help
    Royster- Ontario, Canada
  2. jtown77
    jtown77 Member
    Arizona
    71 Comet
    They do have torque boxes. Look for leaks in the cowl, these tend to cause the floors to rust out. Get a flash light and look under the dash by the fresh air vents. Look under the passenger front fender at the backside of the battery area. Also look at the welded seams where the front fenders bolt on. The bottom of the doors. If the drain holes are clogged up and sometimes even if they aren't you will get a lot of rust there. And the normal quarter panel rot.
    If you get a chance get the VIN number. That will tell you what year it is.
  3. Paul Masson
    1971 Grabber
    :Welcome: from New Brunswick! Check the cowl for leaks, the torque boxes for rot and the front floor pans for rust. Another common area for rust is the very bottom edge of the quarter panels directly behind the rear wheels. With low mileage like that, it SHOULD be pretty good, but who knows?? Post up some pictures if you have any. If it is a REAL Grabber, the 3rd and 4th digits in the VIN will be "93". What colour combo is it?
    Look forward to seeing what you're getting!
  4. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
    Welcome to site! Yes it has torque boxes. As for rust, it's 40+ years old in the snow belt...might be how much as opposed to where
  5. 71gold
  6. 73curtis
    73curtis Member
    ohio
    my car was from Arizona and it was still rotted under the battery.
  7. Craig Selvey
    Something to keep in mind: very little is made for the Mavericks as far as rust repair panels.
  8. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  9. z28th1s
    Lynchburg, VA
    :Welcome: from central VA!
    If the car is a stick shift it will be a 3 speed unless someone has changed it. 4 speeds weren't available in the Mavericks and Comets.
  10. mav1970
    :Welcome:from Northeast Pennsylvania
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
