painting flexible plastic...
Discussion in 'Cosmetic' started by 71gold, Dec 21, 2016.
  1. 71gold
    anyone had any luck with this?
  2. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    No direct experience but may I suggest SEM products with their flexible paint for interior vinyl.
  3. modmav
    modmav Member
    Jamestown ND
    depends on what your painting, a body man once told me there is an additive for paint for use on plastic and rubber but do not recall what they called it though
  4. Mavman72
    Flex additives work well to keep the paint on plastic bumpers/aprons etc... from cracking when hit/bumped etc...
    What are you painting frank??? I have used them extensively. Its a simple additive. just add the proper amount to your base/clear or single stage paint/primer and your good to go. Yes put it in the primer too...
  5. 71gold
    thanks for the info.
    it was also suggested to use an...adhesion promoter... :thumbs2:
  6. 71gold
    PM sent...
  7. CaptainComet
    One bad thing about them is that the paint loses some UV resistance and will fade faster that surrounding paint. Is this on an exterior panel?
  8. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi Frank:
    Just a footnote on painting ' Flexible Plastic ' Now that my Daughters Maverick is almost finished I'm renewing my efforts in the 'Spray-Chrome' setup. We have a complete set of everything required to proceed (chemicals & spray equipment) Spray Booth Areas etc. and I'm going to experiment with the plastic pieces which surround the bucket seats, both sides and backs then the Marker Light Housings .. then finally a MAVERICK and COMET GRILLE . The process isn't too complicated .. but coating the items requires ' preparations' which must be adhered to .. I'll do it on my cars first as a ' test ' to see how they hold up . I'll post the photos online afterwards if anyone is interested .
    Cometized
    (Chip)
  9. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi Frank:
    Regarding spraying ' flexible plastic ' ..Now that my Daughters Maverick is finished , I'm planning on moving forward with the ' Spray-Chrome' process . We have all of the necessary chemicals , spray equipment and Spray Areas set up already . I'm planning to start with the flexible plastic covers that 'surround' some bucket seats and the side cover pieces , then on to Marker Light Housings, then when we ' dial in ' the procedures for the process we'll undertake the ' larger ' pieces like a COMET and a MAVERICK GRILLE .. The process isn't that complicated but the ' procedures ' and time for each of the separate applications must be adhered to faithfully or the results could be less than stellar ! I 'll take photos of the pieces we finish and post them on this forum if anyone is interested .
    Cometized
    ( Chip )
  10. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    OOPS !!
    Thought I " Lost " the first post .. I hit a button somewhere on the keyboard and it was ' GONE ' .. So... I typed ANOTHER ONE .. that's why there are TWO posts about the same thing. Didn't know how to DELETE one of
    them . Anyway .. That's what happened.
    Cometized
    (Chip)
  11. 71gold
    thanks Chip, will be looking for the pics.
    to delete...there is a delete option at the bottom of your post that you want to delete.
  12. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Of course ! I see it now .. Thanks for the tip .
    Sometimes I think my computer has a mind of it's own .. either that or I'm getting more klutzy on the
    keyboard. I'll post the pics on the Spray Chrome process when I can.
    Cometized
    (Chip)
    71gold likes this.
  13. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Yes many times . I use isopropyl alcohol on anything plastic to get rid of static. Just like fiber glass. They use a flex agent in the paint also.
