points
Discussion in 'Technical' started by autogamer117, Mar 31, 2007.
  1. autogamer117
    autogamer117 Member
    Oregon
    I'm trying to set the timing on my 71 302 mav. I have the timing light and know how to use it but I don't know which number mark to use on the number line written on the bottom of the harmonic balancer. I've read that the setting is 6 to 12 degrees, but I don't know what this means.
  2. 71gold
    ...put the old ...condenser...in and see if that helps :yup:
    ...:bouncy: ...
  3. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    Check coil wire. Sometimes they loose contact in the cap when you change to a new cap. Also check to see if coli wire is good.
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Try a new coil, maybe?
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    What Frank said!
    Double check to make sure the coil wire and condensor wire were not accidentally grounded when installed. Also did you set the points in the ramp position.
    Not being mean, but you did install the rotor? Have done it myself!(y)
  6. 71gold
    been there done that :yup:
    ...:Handshake ...
  7. starsky74
    starsky74 Technician
    Hackberry Louisiana
    if i were u i would trash the old unreliable point setup for a crane cams xr-i electronic conversion kit. its simple to install and it has an adjustable rev limiter built in. and you can rely on it. summit p/n is CRN-750-170. it really is worth the extra dollars to get this piece[​IMG]
  8. togetic2002
    togetic2002 Member
    Reno NV
    72 sprint(major reconsruction),92 5.0 ho t-bird
    quick q? if i put a biger coil 40,000 volts in the mave replacing the oem one will it burn out the points faster????:16suspect and how often do i change the points until i get the crane came setup???:16suspect
  9. 71gold
    points should last a while...PERTRONIX...pertronix...pertronix:yup:
    ...:bouncy: ...
  10. rayzorsharp
    I agree...you can install the Pertronix kit inside your original distributor and get rid of points forever. Usually about $70-$90 depending on where you purchase it. Very easy to install and your car will start AND run SO much better.
  11. blugene
    I agree as well...:burnout:
  12. 71gold
    ...if Boogene, agrees with me... I change my mind :p
    ...:Handshake ...
  13. starsky74
    Hackberry Louisiana
    its not how often you have to change out the points, but how often you have to adjust them. which gets aggervating. the conversion kit is so much easier, and you NEVER have to adjust them again
  14. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    Pertronix! :yahoo:
    Try them, you'll never go back.
