rear end possibilities
Discussion in 'General Maverick/Comet' started by Scraperondubz, Dec 11, 2008.
  1. Scraperondubz
    Scraperondubz Member
    Oakland, California
    MAVERICK
    my friend has a 79-93 MUSTANG 5.0 8.8 Posi Rearend and i was wondering will this fit under the maverick or will mods have to be made
  2. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    If you grind all the hardware off, shorten it (or change your wheels) weld spring perches to it and get a new driveshaft or u-joint, sure.
    Early Mustang stuff fits without mods, but any 8.8 will require work. Explorer is the closest to fitting and you still need to move the spring parches and address the width issue.
  3. Scraperondubz
    Oakland, California
    MAVERICK
    Thanks for the info
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I am not sure which ones are offset and which aren't (if any aren't)...
    However, there are issues with at least some 8.8" rears that the center section is offset to one side.
    Just a heads up.
  5. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Rangers and Explorers have the offset 8.8" rearends.
  6. facelessnumber
    Memphis, TN
    '71 Grabber
    Yeah, about 4" offset. People have used them unmodified with higher wheel backspacing, or shortened one side and used two short axles. I plan to do this at some point, and when I do I'll most likely have an offset chunk. Unless I get ambitious, and that could happen too.
  7. ratio411
    ratio411 Member
    Pensacola
    Another heads up:
    The 8.8" rear is heavier than a 9"
    and
    The 8.8" rear has C-clips, which can be dangerous.
    Now if you want a heavy rear without C-clips, you can mod the rear to eliminate them.
    My point is that if you are going to narrow a rear to fit, and move around spring mounts and shock mounts... Why not do all that to a 9" housing and have a rear that is stronger and lighter? My .02
  8. facelessnumber
    Memphis, TN
    '71 Grabber
    Exactly. The only reason I'm looking at an Explorer 8.8" is I already have the wheels it would need to be the perfect width as-is. All I'd have to do is move the perches. If I had to heavily mod a rear I'd do a 9. Hell if I had the money to do that I would just get a Track-Loc carrier and some gears for my 8, which is plenty strong for most people, definitely me.
  9. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    the mustang 8.8 is 1 inch wider per side than stock with the centered pig
    brad:)
