remote oil filter adapter
Discussion in 'Other Automotive Tech & Talk' started by ptpdub, Mar 13, 2012.
  1. ptpdub
    ptpdub Member
    canada Sk.
    what is the word on these things? I have a 302 and want to run one because of lack of space. are they dependable? is one kind better than another? anyone ever use one?
    thank you for your time. :tiphat:
  2. Craig Selvey
    Curious: What is your "lack of space"?
  3. Bizzness
    Bizzness Member
    71 grabber 351w, c6 ,9" 4.56 locker, subframe, roll cage
    I got one. It's workin good so far.
  4. ptpdub
    ptpdub Member
    canada Sk.
    it is on a 53 customline. the cross member is u shaped and the engine sits low. the oil filter runs into the cross member.
  5. Bryant
    used them on several cars. never had any problems and it can make changing the filter very easy.
  6. Streamliner
    Streamliner Member
    I like them but you also need hoses and the adapter where your filter normally screws to the block
  7. jmgford
    jmgford Member
    Iowa
    I had a remote setup on a V8 Ranger that I drove for many years. I had one odd problem right off the bat, unrelated to the actual remote housing.
    I didn't want to use the barbed hose clamp hoses that came with the kit, so I had some hydraulic hoses made up. I had them made of super heavy duty industrial grade material. I ended up with a "moose call" type noise on deceleration, that I eventually found to be a result of a harmonic vibration transmitted through the steel wire in the hoses. I had a second set made of a lower grade, more flexible material and the noise went away.
  8. injectedmav
    injectedmav Member
    Georgia
    Now that is very interesting!:16suspect
    Isn't it fun when an "upgrade" causes some wierd problem you've never considered possible.
  9. ptpdub
    ptpdub Member
    canada Sk.
    Ha, that is kinda awesome!
  10. jmgford
    jmgford Member
    Iowa
    It was awesome when I finally found the problem...................after weeks of tearing my hair out!
  11. Joe Dirt
    90* adapter work?
  12. rthomas771
    A 90* will kill the oil pressure when the oil dead heads into the 90*. Two 45's* will work better. A friend had his oil pressure go from 65 psi to 15 psi usings 90's. If it was air pressure instead of liquid pressure then a 90* will work
  13. Joe Dirt
    I was refering to the explorer/ford motorsport 90* filter adapter i put one on a fox mustang with no oil pressure change fwiw
  14. rthomas771
    Oh !! My bad.
