So how important are...(on the clutch)
Discussion in 'Technical' started by CACollo, Feb 4, 2006.
  1. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    How important are the dowels on the flywheel for the clutch? I got rushed putting my clutch together and left them off, but now i'm thinking i should take everything back apart and stick them in there. I have ARP pressure plate bolts, but don't the dowels take the brunt of the force?
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    As long as all the bolts are in, You should be OK,just hold onto them for the next owner
  3. Acornridgeman
    Wisconsin
    If it were my car, I'd put them back in before running it. I've been involved with one clutch explosion in my life and that was enough for me. :162:
  4. bmcdaniel
    Hmmm, none of my cars ever had dowels, just bolts. With proper ARP bolts you don't have to worry.
  5. grbmaverickmo
    Aquashicola, PA
    If it was mine it would bother me.But I`m picky about the little things.
  6. mavman
    mavman Member
    Arkansas
    How important are they? The better question is, How important is peace of mind?
  7. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Dowels are only used on Late model 5.0's ... not Mavericks ..
  8. Acornridgeman
    Wisconsin
    From earlier posts, he is running either a T5 or T56.
    (And judging from his signature line, he has the horsepower to need the pins)
  9. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    if it was me i'd put em on for the piece of mind, and extra stuff can't hurt )
  10. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    Thanks for all the responses guys!
    I'm running a t5, with a 28oz imbalance flywheel made for the mustang 10.5" clutch. My flywheel actually didn't come with the dowels, which is why i didn't put them in, but i've been running the motor up to 7500 lately and it's been one of those "little" things i worry about (you know, losing my legs :(). It sounds like the general consensus is that i'll be "okay", but i'll definitely locate some and put them in there as soon as i can find a scatter shield to go on with them. And try not to push my luck too far :) Thanks!
  11. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Dowels are usually there to position parts, not take a load. The flange friction and/or bolts are generally what carry the load. I'd be more worried about the clutch not being dead nuts centered. If it's not affecting your shifting, and you don't have a bad vibration, I wouldn't worry about it.
    I saw a clutch let go once. The driver didn't get hurt, but he was picking pieces out of his floor mat. This was in a late model LS camaro launching on slicks and nitrous.
  12. mavman
    mavman Member
    Arkansas
    7500? Hope that's a steel SFI flywheel and you have a "can" to contain it all if/when it breaks. There are some pics over at fordmuscle where a guy was doing a 7000 RPM burnout when his let go....luckily he wasn't hurt, but man oh man, what a mess. Destroyed the car.
  13. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    Eee!! No more stories guys :49:
    That makes a lot of sense, ATOMonkey.
    My flywheel is SFI, and i'm using all ARP bolts. I've been holding off on the scattershield because i'm not sure what i'm going to do about the transmission, but i will definitely get one before i do any serious racing.
