speed
Discussion in 'Technical' started by Tomhopson, Oct 17, 2010.
  1. Tomhopson
    Tomhopson Member
    Jacksonville Florida
    I have a 70 Maverick i-6 200cui, I'm 18 years old and I don't have money for a 302 engine which I plan to get eventually, but for now does anyone know how I can speed it up and make it louder that aren't too expensive?
  2. blugene
    Glass pack?..
  3. Craig Selvey
    Hole saw?
    :D
  4. bmcdaniel
    What transmission and rear end do you have? Is the center section of the rear end smooth or have a cover plate with bolts as view from behind the car? A rear gear change can make a big difference in performance. You can add a turbo muffler and a Y-pipe to the exhaust to have dual exhast tips out the back.
  5. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    Seems a little extreme, I'd use a 1/4 inch drill bit and add holes one at a time with test runs in between to get it just right;)
    Seriously, 2X on the rear gear change.
  6. Dfitzman
    Dfitzman Member
    Taxachusetts
    1971 Green Machine
    I had a rusted muffler on my 71 200, plopped a thrush glasspack on the car and it sounds pretty good. got a little rumble but is a little aggravating on the highway. All in all it has gotten me through my first year with the car until I drop the small block in. It sort of added a little performance feel to the sixer. Oh and best of all under 20 bucks and 20 minutes to install don't forget a chrome tip while your there :)
  7. PaulS
    Shave the head, install an aftermarket hydraulic cam, When the head is off for shaving about .040" off have the manifold milled to accept a 2bbl to 2bbl adapter and put a Ford two barrel carb on it, Have the valves ground an hardened seats installed on the exhaust side, put on a larger exhaust and a muffler that has the same inside diameter as your tube.
    You won't gain a bunch of power but you will notice the change.
    If you have a points distributor in it change to a Pertronics unit if you have the money or put a dwell extender on it (its a do-it-yourself electronic box that makes your points work like a pertronics unit).
    I do have the plans and parts list - along with how to do it instructions that I can email you. (there is a thread somewhere that has the info here but I don't remember where it is)
  8. captainmack
    captainmack Quad Door
    Hey Paul....if you do find that list o' stuff for that 200 build I'd LOVE to get it too.... I have a 200 that just won't die.....I'd love to get ten or 20 HP more...It's a 72 by the way. I have a 250 long block I'm going to do next some day...IF the 200 ever goes down. Maybe that list is applicable to the 250 too? But I really don't know any Guru's down here in Los Angeles. Lot's of machine shops and mechanics.. I love the reliability of my 200 I6 ..I drive it on road trips...LA to Vegas...LA to San Francisco.. I really don't think I'll ever do the Aluminum CI head but milling down the stock log and a little 2 barrel as long as it fits under the hood would be cool. I just spent the last hour searching for that list on this forum...ha ha..can't find it :( It's valuable info I know...
    Thanks for all your great posts.
    Mack
    Captainmack@gosailnow.com
  9. PaulS
    Mack,
    the carb change fits under the hood :
    http://mmb.maverick.to/showthread.php?t=57193 post #2
    http://mmb.maverick.to/showthread.php?t=56250 post #17
    these are how it works.
  10. maverick75
    Fordsix.com has endless info. Something cool is that a milled down 2bbl conversion late 250 head will flow just as much as a crossflow OZ head. Im building a turbo kit for the 200 in the falcon that im building. You can find my videos on youtube by searching for acmav289. I have a dual exhaust system on it.
  11. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
  12. maverick75
  13. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    go to fordsix.com like mentioned before, good guys there.
    ---short and sweet version---
    you want loud
    y-pipe into dual glasspacks (12")
    you want fast
    -bore 30 over, port the head and 3 angle valve job and mill the head (for 9.1 compression), run port divider, run headers, run offy triple carb setup or 2 barrel, go with the 71' timing chain (250 only), duraspark II ignition, swap to an electric fan. put behind a T5 tranny.
    you want faster
    turbo charge it
    building a six aint cheap but they are different and sound good.
  14. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
