Trunk Light...
Discussion in 'Technical' started by RASelkirk, Feb 22, 2009.
  1. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Got one (from a member here) off E-Bay, anyone got pix of how this thing is supposed to mount?
    Thanks!
    Russ
  2. rthomas771
  3. mean_maverick
    ive had 24 mavericks/comets and only one has ever had the trunk light :) kinda hard to find but they're a nice option for a DD in wal-mart parking lot :yup:
  4. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Thanks, I have CD version of the parts book that has that diagram and forgot about it. :oops: I've been having a problem orienting the socket so it turns off when the lid is closed. I see why, I don't have that square hole in my lid!
    I have the "Mustang" version of locking gas cap that requires opening the trunk and pulling back a spring-loaded rod to turn off the cap. A light will make it easier...
  5. yellow75
    Tillamook Oregon
    I have had 5 Mavs with the trunk light and a couple with the under hood light. I just checked 4 trunklids,3 - 72s and a 75 and they alll have the hole for it. :hmmm:
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    DOH! Is this the hole? I might have not been looking in the right place...
    Russ
  7. Dave B
    It's the one on the other side, the wire for the light follows the driver side trunk hinge. If it would quit snowing, I'd go out to the garage and take a picture of the one on my 74 for you.
  8. yellow75
    Tillamook Oregon
    What he said :thumbs2:
  9. Craig Selvey
    It is here:
  10. yellow75
    Tillamook Oregon
    Craig, I have seen them in both places. Picture shows them in lower location though. Personally I think you get better light from them were you have it located.
  11. Dave B
    I tried to get as close as I could, but there is way too much stuff in my garage. I took a picture of the light, and where the wire comes out.
  12. mean_maverick
    same as my '73 4dr....
  13. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    1972 Maverick 2 Door Sport Sedan Grabber
    Just something to add.
    Don't know about you guys but the ole 72 didn't have one, or an under the hood light--but the guy who had the car before me put a switch by the mounts around the gas tube and ran one up and under the back part of the trunk(under the rear window deck close to the lip of the trunk--hence gives light where you need it, in the trunk not way up on the open lid. Works well, only issue I have with his set up is the lights have to be on and I have to throw the switch--be nice if it'd just come on.
    So, if it doesn't make a big difference, you might ck out how you like the lighting there before you put it up on the trunk lid.
    Have fun!
  14. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Thanks to all for your help! Since I don't have anything now, I'll try both locations and pick the one I like best.
    Russ
  15. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I put mine in like Dave's (didn't have any other option) and it works just fine. Don't know how I overlooked those big rectangular mounting holes! :huh:
    Thanks All,
    Russ
