What year calipers are these??
Discussion in 'Technical' started by mrcomet, Nov 13, 2013.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Hello,
    My Comet had front disc brakes put on before I acquired it. I am trying to determine what year the calipers are so I can get the proper brake pads. A mechanic put on pads that are for a 74 Comet and they are not the right size. They continually rattle.
    The pictures show what looks to be a single piston caliper. They are Ford calipers and one of the is stamped "1967". From the pictures I've seen in the research I've done it seems they may be actually 1968 calipers manufactured in 1967. Pictures of 1967 caliper had 4 pistons.
    Can you all take a look and let me know what you think the right year is. Once I get this down I can get the right pads and cure the rattle issue.
    Thanks!
  2. Dave B
    Those look like the 74-77 Maverick disc calipers. Did he clean up the slider?
  3. 71gold
    do they have the...anti rattle clips...installed?
  4. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    yes, the anti rattle clips are on.
    How could these be for 74 to 77 comet if they are stamped 1967?
  5. Krazy Comet
    Those are most assuredly mid 1970s to early '80s, about every Ford vehicle used a similar caliper in that time period...
    This is '68-'73 Mustang & '68-'71 Torino brakes...
  6. Dave B
    Where are they stamped 67?
  7. blugene
    I see it in that last pic..
  8. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    On the last picture there is a flat tab at the top of the caliper and it is stamped "1967"
  9. Dave B
    That doesn't mean it's 1967, that's something that's been added later probably by a rebuilder. The 4 letter casting code is where you get the date.
  10. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    The casting code on one is 7274.
    On the other it is 8270.
    What does that tell me?
  11. Krazy Comet
    That those aren't FoMoCo casting date codes, or even a basic part number for a caliper... Ford uses a alpha-numeric system that repeats the next decade...
    Would read 8L14 for Nov 14 1968, 4L14 for Nov 14 1974, 5A2 for Jan 2 '75, etc...
    It could be a date system that uses year and number of day, but I didn't think Ford used such... In that case it could be 1977, 274th day and 1978, 270th day...
