3 speed Transmission Bracket
Discussion in 'Technical' started by Johng1970, Feb 10, 2013.
  1. Johng1970
    Johng1970 Member
    Freeport, PA
    My 3 speed tail shaft does not have the 3 bolt holes on it. Do they make a bracket that fits over the tail shaft or do I need to change the tail shaft?
  2. Craig Selvey
    If you are talking factory parts, I believe you will need to change the tail-shaft. On the 3-speed transmissions I have parted out, the tail-shaft was different for a floor shift car versus a column shifted car.
  3. bmcdaniel
    Yep, best way is to find a tail housing for a floor shifter. They used to make brackets to adapt, I had one on my car that was originally a column shift converted to floor shift. It places the shifter way over to the left and you need to cut a huge hole in the transmission tunnel. Much cleaner installation if you use the correct tail housing.
  4. fomoco74mavgrab
    fomoco74mavgrab Member
    wi
    74 mav
    I have a factory floor shift tailhousing for a 3 spd toploader.... With a good shifter (has good bushings)
    Let me know...
  5. Johng1970
    Johng1970 Member
    Freeport, PA
    fomoco74mavgrab,
    Would you happen to have a picture of what you have? How much were you asking for it?
    Thanks John
  6. fomoco74mavgrab
    wi
    74 mav
    I'll send you an email...
  7. fomoco74mavgrab
    wi
    74 mav
    From a 71 mustang, Used it for about 10 years. hurst t handle knob
  8. Johng1970
    Johng1970 Member
    Freeport, PA
    How much were you asking for it? And where are you located?
