4 to 5 lug conversion
Discussion in 'Technical' started by 70mavRick, Mar 24, 2010.
  1. 70mavRick
    70mavRick Rick Falk
    Havelock, NC
    1970 Maverick (Grabber Clone) 1970 Maverick
    I'm converting my 1970 Mav to a five lug. What rear brake drums are compatable with a 1975 Maverick five lug? (Having trouble finding them at the local auto parts outlets) and after reading all the threads on wheels sizes; I found these at summit racing:
    [​IMG]Wheel, 141 Legend 5, Aluminum, Gunmetal, 15 in. x 7 in., 5 x 4.50 in. Bolt Circle, 3.75 in. Backspace. Will they fit with a -7.00mm offset and 83mm center bore diameter?
  2. Acornridgeman
    Wisconsin
    Drums should be available at any auto parts place. Rock Auto has them for sure.
    www.rockauto.com
    :tiphat:
  3. comet416
    comet416 Member
    michigan
    1970 maverick
    i couldnt find 5 bolt drums for 9" brakes so i had to switch to 10" backing plates and brakes.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Couldn't you just re-drill the originals?
  5. 70mavRick
    70mavRick Rick Falk
    Havelock, NC
    I do not have the originals. Trying to keep it within a reasonable budget, rockauto has them them listed at $110 a piece. Any help on the wheels?
  6. Acornridgeman
    Wisconsin
    Was your original rear a late 1970 with an 8" 4 lug? If so, just swap over the 10"x 1 3/4" backing plate brakes and buy new 5 lug drums. They are only around $25.
    If your old rear was not an 8", you can probably pick up the needed brakes used in the classifieds.
