69.5 differences
Discussion in 'General Maverick/Comet' started by wmw99a, Feb 2, 2005.
  1. wmw99a
    wmw99a Member
    College Station, TX
    69.5, 200ci, stock.... for now
    Key on the dash...not on the column.
    Horn ring on steering column instead of a horn pad.
    Metal data tag on the door instead of a data sticker on the door jamb.
    Different type of sticker located on trunk lid not found on any other year of Maverick (68-69 Ford's and Mercury's had them. Called a "Safety Act" sticker. Ford part #C8AB-6220472-A Jim Osborne reproduces it.)
    Front suspension had a 4-bolt ball joint and 1970-197 had a 3-bolt.
    Anything else???
  2. inline6
    inline6 Member
    gas tank on the 69.5 was a drop-in,(top of tank was part of the trunk floor)all others were mounted under the trunk floor.scuff plates are different alltogether,backseat mounting locations different.inside of car,under the winshield seal,different #of screws that hold the dash to the cowl area.also the 69.5 was based on the falcon chassis,and i do believe the tranny tunnel on the 69.5 is a little narrower than the later years.
  3. Mavaholic
    All 70's were drop in, not just the 69.5
  4. 357 Grabber
    357 Grabber Maverick DieHard
    kentucky
    2 71 grabbers,72 Maverick , son has a 73 maverick
    Trans tunnel much smaller too
