70 maverick t10 swap questions
Discussion in 'New Members Forum' started by 70maverick6er, Aug 4, 2014.
  1. 70maverick6er
    70maverick6er Member
    new hampshire
    1970 maverick i6 auto
    hello again im in the process of collecting the parts to
    convert my 170 i6 c4 to a 302 and a t10 4 speed.i just picked
    up a 68 302 super clean,and a 65 borg warner t10 close ratio.
    so a few questions... the longer speedo cable needed for the
    4 speed swap what do you use?and second what shifter will
    fit the maverick the best a mustang or falcon shifter.i have the
    stock 65 mustang shifter and linkage but I think I read somewhere
    aftermarket hurst ones fit without tunnel extension.any insight would
    be appreciated
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    The T10s had different length tailshafts. The Falcon has a shorter shaft than the Mustang and the shifter mounts about 4 inches farther forward. The falcon crossmember mount is also different. I would get a hurst shifter with the appropriate adapter and linkage.
  3. 70maverick6er
    new hampshire
    ok I have a mustang trans so I should get the mustang shifter then,also
    do you know about the speedo cable?
  4. Maverocket
    Northwest
    You will want to use the mustang shifter or Hurst equivalent and I used a 70 Mustang manual speedo cable on my car (it's a couple inches longer).
    70maverick6er likes this.
  5. 70maverick6er
    new hampshire
    thanks for your help.
  6. Maverocket
    Northwest
    Absolutely, that's what the forums all about.
