A Little Maverick Trivia (maybe)
Discussion in 'General Maverick/Comet' started by Dave B, Sep 2, 2007.
  1. Dave B
    Some of you may already know the answer, but where did Ford use Real Leather on Mavericks??
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    some dash emblems were leather
  3. Dave B
    A little more common than that :)
  4. Shinysideup
    Shinysideup Chillin the most
    town
    car
    Is this a trim piece? My first guess was the 'rag joint"?
  5. Jamie Miles
    Alto, GA
    I've had a few
    No idea...
  6. Dave B
    We'll let it run for a bit, and see if any of the long time Maverick guys know, If you've totally stripped a car from everything you might know :)
  7. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Rawhide lip seal on the engine!
  8. Jamie Miles
    Alto, GA
    I've had a few
    Done it three times, and I have no idea...
  9. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    I know I have a factory floor shifter and the boot is definately leather but that would only be a few cars.
  10. Jamie Miles
    Alto, GA
    I've had a few
    That is rubber.
  11. Tom Laskowski
    Bay Area,California
    Oil Seals
    Chicago Rawhide CR Oil Seals are designed for the sealing of openings between a rotating and stationary component or between two components in relative motion. In simplest terms a seal is a barrier with four functions:
    1) Retaining lubricants or liquids
    2) Excluding contaminants
    3) Separating fluids
    4) Confining pressure
    Many Chicago Rawhide CR seals have the patented Waveseal lip design that pumps lubricant back to the oil cavity while holding out contaminants, regardless of the direction of shaft rotation. The smooth molded lip is formed in a wave-like pattern that describes a wider path on the shaft to dissipate heat and reduce wear. Chicago Rawhide CR is the worlds leading supplier of fluid sealing devices for the truck, automotive, agricultural machinery, and machine tool industries.
    Boretite coating contains rubberized OD bore sealant that fills small imperfections in the bore.
    Molded smooth lip provides 20% less frictional torque (drag) with 25% to 35% less heat generation resulting in power savings and a reduction of the possibility of early failure.
    Bi-rotational wave lip eliminates conventional wear tracks. There is little or no shaft grooving, and it pushes dirt away from the seal and pumps lube back toward the bearing.
    Dalton Bearing Service is proud to offer a full line of Chicago Rawhide Oil Seals. Whether you have questions on pricing or technical information for any Chicago Rawhide Oil Seals , Dalton Bearing Service is ready to assist you. Please use the "Request for Quote" section of our website for a prompt response to any questions regarding Chicago Rawhide Oil Seals.
  12. NICK DOMINICK
    Burke, Virginia
    This is a tough one. I should know but I can't think of it. I can't wait to find out the answer and see if I knew the answer and didn't remember or if I learn something new.
  13. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I have no idea.
    Dan
  14. Dave B
    It's not a oil seal, but it does seal something.....
  15. Mavman72
    Gas tank filler pipe seal on trunk floor. Mine is original and it does not feel like rubber.
