Air Conditioner
Discussion in 'Technical' started by saltracer, Aug 8, 2007.
  1. saltracer
    saltracer Member
    Louisiana
    Does anyone have experience with updating the entire air conditioner system in their Maverick? Does the complete after-market unit for a Mustang/Cougar work? thanks Phil
  2. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Phill
    I could not get any good answers about after market a/c units . What i did is to use a mix of old and new . Everthing under the dash is factor a/c 71 vintage and under the hood is new, rotory compressor ,4 pass condenser and new hoses and 134a feron and fan on condenser . However not happy with the temp. out of the ducts with the 134a i will be changeing back to R12 freon .
    hope this helps
    JAY
  3. 71gold
    i did the same as Mavdog.
    the 134 wasn't as cold as i liked it to be so i ..insulated...insulated...insulated. i can now run it on ...low...and be cool.
    ...:Handshake...
  4. saltracer
    saltracer Member
    Louisiana
    Hey Mavdog,
    Where did you get the updated stuff for under the hood? thanks Phil
  5. newtoford
    newtoford Member
    New Castle Delaware
    do you have a v8? im sure 5.0 stuff from the late 80's early 90's is a step up from the vntage 70's stuff. probably not that much harder to hook up either since it is the same engine
  6. Shinysideup
    Shinysideup Chillin the most
    town
    car
    Id like to see if a foxbody mustang unit
    will fit under the dash. Anyone done this yet? I have a complete system, just havent had a chance to try.
  7. 71gold
    i had an A/C shop that does a lot of street rods do mine.
    ...:Handshake...
  8. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    You forgot the million dollar question..........what was the cost to do it?
    Robert
  9. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    I have a completely different A/C-heater system in my Maverick. The under dash box is from a 1980-81 Thunderbird, and so is the entire dash. Under the hood I am using an A-6 compressor from a '75 Monarch. I also modified the system so it uses an electronic head unit from a 2000 Crown vic, so the car now has fully automatic climate control...
    That said, you probably don't want to go as radical as that. :) I don't know too much about the complete aftermarket units, but i believe it would be far easier to use a factory A/C-heater box under the dash and then add a modern compressor and condenser under the hood. Using a factory A/C box makes things somewhat easier because you won't need to modify the existing dash...
  10. 71gold
    what is it with you people?
    ...if it ain't...what color...it's what did it cost...:slap:
    ...:bouncy:...
  11. RobertBailey
    :sorry: Just courios since mine has no a/c:grouphug:
    Robert
  12. scooper77515
    Cum on, a ballpark would be nice...such as "more than $500" or somewhere around $1500"...:huh:
    There are some of us down "south" who just aren't driving their cars because it is a "balmy" 96 outside...:mad:
  13. 71gold
    i thought you took the A/C off...
    because you change ...cams...so often :huh:
    ...:bouncy:...
  14. 71gold
    this sounds like a ...TL question...did he e-mail you and ask you to ask me what i paid for my A/C ? :huh:
    ...:rofl2:...
  15. scooper77515
    No, he didn't, but I AM getting e-mails from him...civil ones, at that!
    I took mine off because it was in the way!
    I plan on putting one back on, but not ON TOP OF the engine. I want to mount my compressor where the alternator is, or below it, and run a complete aftermarket system.
    I couldn't stand moving all that crap out of the way when I was working under the hood.
    By the way, I have only swapped ONE cam...
