Air Filter Question.
Discussion in 'Technical' started by Stwjester, Sep 18, 2009.
  1. Stwjester
    Stwjester Member
    Lexington, KY
    1970 Maverick(Mod Grabber)
    Just recently aquired a '70 Maverick with a Grabber Hood on it. It doesn't have an Airfilter on it, and your standard 2 inch Airfilter doesn't have enough clearance to fit. Any suggestions on a low profile air filter to use with the Grabber hood? Or has anyone else run into a Similar problem.
    The Engine is basically a stock 200CID I6. Thanks in Advance.
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    if you are running an after market set up you may need a 1 inch tall filter or a bottom mount that is slightly recessed?
