Alignment specs
Discussion in 'Technical' started by MeanGreen72Mav, Feb 13, 2012.
  1. MeanGreen72Mav
    MeanGreen72Mav Member
    Taylor, Mi
    I just completed a full front suspension and steering rebuild with the Granada disc brake swap. I also converted the power steering to manual with the Rare parts adapter. I am running 235 60 14's on Magnum 500's. Now I'm ready for the alignment. The question is ... what specs should I tell them to align it to?
    I have come across a few different threads that address this issue, but I come up with several different specs. So I guess what I'm really asking is what specs are you guys using and how does the car handle?
    Any info will be appreciated
    Thanks
    Kevin
  2. bmcdaniel
    You're running 235/60/14s on the front?
    The old published specs for our cars were for bias tires. I assume you are running radials which throw the old numbers out the window. For mine, after some trial and error, I settled on:
    Caster = +2.75*
    Camber = 0*
    Toe = In 1/16"
  3. MeanGreen72Mav
    Taylor, Mi
    Yes, the tires on the front are pretty wide, but I like the way they look. All 4 tires are the same size. I got them from a 1972 Gran Torino.
    Thanks for the specs
    Are you coming to the Roundup again this year?
  4. bmcdaniel
    I'm planning on it.
  5. MeanGreen72Mav
    Taylor, Mi
    All right, well hopefully see you then. Thanks again for the help.
