Another question
Discussion in 'General Maverick/Comet' started by SamsDad, Apr 17, 2014.
  1. SamsDad
    SamsDad Member
    Little Rock, Ar
    1973 LDO turned Grabber Clone
    OK, so I have another opportunity to acquire a roller out of a Mustang GT with less than 100k miles on it and it has all the stuff still on it i.e. power steering pump, AC compressor and the full serpentine belt and all pulley's.
    Will this motor drop into the 73 Mav and everything fit, it would be so nice to have one belt driving all the accessories or is there a gremlin in the mix?
  2. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    I don't recall if there is an issue with the rear-sump oil pan on the 5.0L motors. Also, check fan- to-radiator clearance and if you're planning on sticking with the EFI, check the upper intake-to-hood clearance, as well. Everything else ought to work out.
    Eric
  3. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    You would need a front sump oil pan and late model flexplate.
  4. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    Oh, yeah... forgot about that. Good catch.
    You need a 28 oz. flexplate if you're keeping the C-4, or, a 50 oz. if you're going AOD. Also, make sure the converter bolt-hole spacing and flexplate tooth-count sync up with your application, too.
    Eric
  5. Maverocket
    Northwest
    You will need the 50oz. flexplate regardless of the trans your using. A 28oz. used on the 5.0 will create an imbalance.
  6. SamsDad
    SamsDad Member
    Little Rock, Ar
    Ok
    Thanks for info, I will be tossing the fuel injection and putting my heads, intake and carb on it, also planning on tossing fan blade and running flush electric fans on a new aluminum rad, so sounds like this will work, man this will save alot of work and exspense......thanks again
  7. Maverocket
    Northwest
    Sounds like a good plan, now to find a cam that works with that setup.
  8. lm14
    lm14 Member
    Iowa
    You may need to change the timing cover and add a fuel pump drive to the cam?
    Fuelie motor wouldn't have either of those items. Somebody else will be able to confirm this if it's an issue. Also, if you do have to change the timing cover, water pump rotation/cover compatibility may be an issue.
    SPark
  9. Maverocket
    Northwest
    The 5.0 blocks are also missing the boss for column shift linkage. If you run an electric pump and floor shifter these won't be a problem.
  10. 71gold
    break it down to a...long block...and start from there.
    100K is a little much to just cam and new heads...JMO
  11. Krazy Comet
    If you're running a C4 with 157 tooth flexplate, the 50 oz required will be a custom piece(still readily avail), no factory combo used this...
    Also you'll need a steel gear for the cam, non roller engines use iron gear that may last 10K mi...
  12. mav1970
    Changing over to a front sump pan, you also need the matching oil pump pick up that goes to the bottom of the sump :)
  13. SamsDad
    SamsDad Member
    Little Rock, Ar
    Yep
    OH we are still going to do a total rebuild, machine work, bearings, all of it. I just wanted to make sure it would run with the serpentine set up turning everything plus it comes with the AC compressor and the oil pan and flex plate is no prob, the whole works will be balanced at machine shop.
    I didn't mean to imply I was going to just toss this motor in "as is" lol
  14. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    Not if you install a 28 oz. damper up front use a pre-'82 302 crank machined to fit the 5.0L. Was, like, $100 back in the day.
    I've done this to a 5.0L carb conversion where I just kept the roller block and retro-fitted a carb set-up backed by a C-4. This was before the retro-fit roller kits were available.
    Eric
  15. mav man
    mav man Member
    wi
    70mav
    You can get a timing chain cover with the hole for fuel pump and cam eccentric for pump that works with both reg and rev. Water pumps from jegs or summit.they will also have the oil pan and also the 50 oz flexplate its not a custom piece. I had the same setup in my 77comet.I also ran a composit gear on dis.then you don't have to worry about gear chewing up the cam
