AutoKrafter Fuel Sender
Discussion in 'Technical' started by dmhines, Oct 26, 2004.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I purchased an AK fuel sender a while back .. pretty sure they weren't $70 like they are now. Anyway ... the fuel guage needle goes way past F even prior to it being full. As in way past .. I mean you can't see the needle. Are there any adjustments that can be made or is it just a defective product?
    What really sucks is I know for sure I don't have the freakin' reciept for their 5 year replacement warranty.
  2. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    I had the same thing happen except my problem was the circuit board on the back of the spedo.
  3. RegL404
    RegL404 Member
    On the instrument cluster regulator you will see a flat copper strip sticking out from where the metal halves are crimped together,this is what grounds the regulator. I have seen two or three lately where I took a pair of side cutters and crimped the metal halves tighter onto the copper strap and fixed the gauge acting just like yours. HTH Reggie
  4. dmhines
    Cumming, GA
    Thanks ... I'll give it a try ...
  5. Craig Selvey
    Yep...sounds like the instrument voltage regulator.....easy to fix.
  6. black396
    black396 Member
    florida
    Comet
    "What really sucks is I know for sure I don't have the freakin' reciept for their 5 year replacement warranty."
    ~~~> It is a violation of the MAGNUSON-MOSS WARRANTY ACT, 15 USC, section 2304(b), for them to require a receipt. The act states, in part, " The warrantor shall not impose any duty other than notification upon any consumer as a condition of securing remedy of any ...product which... is defective..."
    This language has been interpreted by the FTC, which makes the rules, to mean no receipt required.
    CR
