Hello, How does one remove the back seat without breaking anything? I may not be looking hard enough, but I can't seem to find any bolts or anything to undo... Thanks! Atzy.
Try this.... The correct way to remove your back seat is to get a rachet and socket extension (don't remember what size). You then slide your hands between the backrest and the seat (in the crack) and in the middle of the place where someone sits (each individual "seat" if you want to call it that) on each side there is a bolt you undo. If you don't quite understand what I mean feel around in the crack and you will find them. A flashlight will help as well. After these are out the seat back will need to be lifted up and away from the package tray as little "clips" hold it there. The bottom, is basically lifted up and back to free it from it's "clips". It sounds a little wierd right now, but when you try it, it will be tons simpler than it seems. After the first time you will be a seat-slingin' pro!
