Bad ground or short
Discussion in 'General Maverick/Comet' started by 55crownvic, Dec 24, 2014.
  1. 55crownvic
    55crownvic Member
    colorado springs
    Been wiring the sequentials on my mav and finally got it ready to test out. They work great!!! EXCEPT when the front t/s bulbs are in place, then everything gets eratic and fast blinking. I have changed the t/s switch, cleaned the contacts on the fuses, grounded everything I can. Am wondering if it might be in the ignition switch/wiring, have a new headlight switch but an old ign. switch. Replaced the front sockets. Park lights work, wipers, dash lights, heater, but the front t/s make the rears go goofy. Got any ideas?
  2. Bryant
    i dont know how sequentials work but i do know that with a thermal flasher, you need the proper load on the circuit or it wont flash or go to fast i think. i would switch to an electric flasher if you haven't done that yet.
  3. yellow75
    Tillamook Oregon
    Did you use relays and a new power source for the sequencer or just hook it up to the existing wiring going to tail lights also did you ground each tail light socket individually, I hate electrical problems and I am an electrician. Bryant is correct about flasher but when I did mine I just used the existing flasher and they work fine.
    I drew up a diagram of how mine are wired and is in the tech section if you can make sense of it.
  4. Krazy Comet
    At least some of the sequential kits require a electronic flasher...
    Al long as you're getting 12v through the switch, wiring, etc, that isn't your problem...
  5. bmcdaniel
    I used an original style thermal flasher with mine but I opened it up and bent the contact some to slow it down. Took a little trial and error to get it right. I have an electronic flasher that I was going to make adjustable by putting a potentiometer in where the resistor is but haven't fooled with it yet.
  6. Acornridgeman
    Wisconsin
    Pick up a heavy duty flasher. That should do it.
  7. 55crownvic
    55crownvic Member
    colorado springs
    I did some more work on my t/s's and have found the problem to be in fact, the flasher, as you guys have said. I have the turn signals working great, but the hazards dont work as well, but they DO work. So I am going to try a heavy duty flasher tomorrow as soon as I can get one, Thanks guys!!!!!
  8. Acornridgeman
    Wisconsin
    There are 2 flashers, one for the directional and one for the hazards.
    As Bryant said above - they need to be matched to the load (number of lamps) in your circuit.
  9. 55crownvic
    55crownvic Member
    colorado springs
  10. Acornridgeman
    Wisconsin
    Cool! Glad that was an easy fix, unlike a bad ground problem which can drive a guy nuts figuring out ................ :bouncy:
  11. 55crownvic
    55crownvic Member
    colorado springs
    yeah, this was the best christmas present I got!!!!
  12. Bryant
    so your saying a flasher is the best christmas present ever! lol
  13. 55crownvic
    55crownvic Member
    colorado springs
    No, just for THIS year, wasnt so lucky in OTHER areas, lol!!
  14. Acornridgeman
    Wisconsin
