bell housing
Discussion in 'Technical' started by pyro, Feb 9, 2006.
  1. pyro
    pyro New Member
    tallahassee,fl
    Will a 250 bell housing bolt up to a 302 or will I have to get a 302 bell housing?
    thanks
  2. Jamie Miles
    It will bolt up fine.
  3. don graham
    pyro, jamie is right the 250 will bolt up fine. of course you're driving a ford. there's always exceptions. are you putting in a stock 302 with exhaust manifolds or are you going for headers. if you use headers you might need to get the small bellhousing, flexplate, and engine plate. this allows for the header clearance. i've asked before, but i don't think i got an answer, is anyone using the bigger bellhousing and using headers? did you have any clearance problems? thanks.:)
  4. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    I have the stock 302 motor and its orginal bell housing with headers and there have been no clearance problems with the housing.​
    Dean
  5. pyro
    pyro New Member
    tallahassee,fl
    I not sure about the headers probably not though I have not thought that far yet.:hmmm:
    I haven't even gotten the 302 yet.
    My buddy has one that I might get rebuilt or if I come across a real good one close to Tallahassee,fl that I don't have to rebuild I might just drop it in.
    I am going to send the tranny to get rebuilt and wanted to make sure I had everything in order before I sent it.
  6. don graham
    dean, do you have the 157 or the 164 tooth flexplate?
  7. Dean Deeter
    Dean Deeter Member
    I have no idea sorry.
