Body parts rubber plugs/gromets
Discussion in 'New Members Forum' started by 351ho, Nov 22, 2007.
  1. 351ho
    351ho Member
    Granite Falls NC
    1970 170-6 3ontree reverse lockout.1954 f100 custom cab.1978 cobraII factory air.1985 f150 4wd 351ho.1984 tempo/driver.
    Anyone know where I can get new rubber seals for all firewall openings? Steering colum,clutch rod,master cylinder,heater hoses,break lines...ect.
  2. rayzorsharp
    Check with one of the large Mustang vendors. They should be pretty much the same. Do a Google search for "Mustang parts vendors"
  3. 71gold
  4. newtoford
    newtoford Member
    New Castle Delaware
    welcome abord
  5. Craig Selvey
    Mustangs have the same plugs for a lot of the Maverick stuff.
    Steering column is Maverick specific and you can get at Auto Krafters.
    Clutch Rod: Auto Krafters (I think)
    None needed for the master cyl
    I don't think anybody makes the heater hose grommets.
    Nobody make the brake line grommets.
    If you need the firewall plugs for a factory AC car to cover up where the non AC heater core was located.......Cougars use the same plug up on the cowl.
