Brake swap
Discussion in 'Technical' started by chase259, Feb 23, 2014.
  1. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    So I have a 1970 ford maverick and a 1977 mercury comet parts car, I'm looking to swap the brakes, I have all the instructions on how to do it but I'm wantin your guys opinion because I'm worried about doing this and messing it up. From what I've read I take the spindles and simply swap all the parts and bleed the system but if you guys have any tips or advice that would be amazing :)
    P.s. This is the instructions I'm following "http://www.maverick.to/grabber/frontdisc.html"
  2. Angryeyes
    Angryeyes Member
    Canada
    Mercury comet, chrysler 300, Kawasaki ninja 600
    I believe they should swap over, just pound put the cotter pins, swap the spindles over, replace with NEW cotter pins (important for everything imo) get the brake lines hooked up, and bleed the system. Might be worth mentioning that you may want the disc-drum master cylinder :)
  3. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    Haha thank you for the advice, I'll just put on my big boy pants and do this haha I wish there were more mavericks in calgary who could come take a look and give me a hand lol :p
  4. Angryeyes
    Angryeyes Member
    Canada
    Well im in Regina! Thats kinda close lol
  5. bmcdaniel
    bmcdaniel Senile Member
    If you use the 70's hardlines you'll have to bend the hardlines slightly at the wheel well, they're not quite the right length. I fabbed new brakets out of slotted angle for where the hardlines and hoses meet. You might have the brackets you need on the donor car.
  6. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    No the brake lines, can we get new ones online or anywhere?
  7. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    Haha my grandparents live in Virden maybe when we drive through I'll stop and say hi
  8. Angryeyes
    Angryeyes Member
    Canada
    Id actually be down for that. Can always make time for coffee. And yeah, brake lines may need to be redone. I neglected that since im redoing all the brake lines in the car anyway so i hadnt though of it, my bad
  9. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    Is there any DIY forums to install the front brakes because I'm wondering about using an aftermarket brake booster and master cylinder and how to install all of this
  10. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    Also with the brake sway where can I find 76 brake hoses?
  11. Dianne
    Dianne Member
    Nampa, ID
    1970 Ford Maverick, 1973 Grabber, 1973 Pinto Wagon, 1978 Mustang King Cobra II, 2004 Mustang Convertible
  12. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You can get the 76 hoses through any auto parts store. On my 70 I used the frame brackets from a disc brake car such as your 76 donor. I cut and re-flared the hard lines to mate with the hoses at the frame bracket.
  13. Dianne
    Dianne Member
    Nampa, ID
    Sheesh, I guess I went the hard way to do my 70.
  14. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
  15. Krazy Comet
    IF you have a '69½, the tie rods will be too small for the spindle sockets...
    I'll guess the original hard line fittings will be a different size at both the M/C and at brake hoses, best bet is swap all the lines... May be able to use adapter(s), but AFAIK there is no adapter from the 9/16" outlet on orig M/C to a smaller size...
    I just went through all this on my Comet, but I did use '69 Torino brakes vs later Mav/Comet components... I used a adapter on the rear port of M/C but otherwise cut the original lines, repl fittings with proper size and re-flared...
