Brakes are so squeaky.....
Discussion in 'General Maverick/Comet' started by TrotMaverick, Mar 2, 2012.
  1. TrotMaverick
    TrotMaverick Tyler Trotter
    Gaston, Oregon
    1972 Ford Maverick Grabber, 2016 Chevy Sonic
    Hey all, long time no see! Just did my brakes (drum) since my hold-down pin managed to break off and thrash my shoes/drums....However, my brakes are super squeaky, it sounds like the front-passenger wheels that are squeaky but its hard to tell for sure. Any ideas on what could be causing it? :hmmm:
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Did you have the drums turned? Did they get scored when the pin broke? Many years ago I replaced the shoes without getting the drums turned and they squeaked.
  3. mercgt73
    mercgt73 Member
    Take some emery paper and scuff the inside drum surface real well (in the same general direction of rotation). Do the same to the shoe surfaces. This will remove any glazing that the shoe or drum surface might have developed. Give it a go and see if the squeak goes away.
  4. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I always douse everything in brake parts cleaner during reassembly, just to make sure no debris finds its way between the shoe and the drum.
  5. TrotMaverick
    Gaston, Oregon
    Cleaner we did lots of, replaced both back drums but not the front.
  6. Joe Dirt
    cheap shoes have lots of metal dust in them
  7. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    They have removed asbestos, (per EPA) and added metal to all brakes.
    That is why brake pads outlast the rotors.
  8. 71gold
    is it a...pulsing squeek or one long squeek as long as you are on the brakes?
  9. 71gold
    I do this but use...80 grit paper...
    I block sand...my pads to get a flat surface...:yup:
    if i don't turn my rotors, i glassbead them...
    ...wear a dust mask...
  10. TrotMaverick
    Gaston, Oregon
    A little bit of both actually...normally when i first start driving it is constant...but there is also a pulsing squeak from time to time when i stop and it tends to grab when it pulses.
  11. 71gold
    mine were pulsing the other day...found a bent axle flange on the drivers side...new axles ordered, should be here today...:thumbs2:
    thinking it happened the other day when it went sideways when it hit 2nd gear...:chirp:
    http://www.sdgearaxle.com/
  12. Ol Maverick Man
    Wallingford, Ct.
    Squealing is actually a high speed chatter. Make sure drums and brake shoes are true.
  13. scooper77515
    I drag mine back and forth on the concrete driveway. That should be right around 80-grit...
  14. TrotMaverick
    Gaston, Oregon
    What do you mean by "true"?
  15. Ol Maverick Man
    Wallingford, Ct.
    Brake drums are trued by turning them down on a brake lathe. Brake shoes should make full contact with the trued drum. They can be rearched, but it is rarely needed. They will seat themselves after being driven for a few hundred miles.
