Bushing Kit
Discussion in 'Technical' started by Ford Guy, Feb 20, 2007.
  1. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    I'm looking to replace the old rubber bushings in my '73 Grabber with some polyurethane ones to get better handling. I was wondering if a kit for an early mustang would work, and if so, have any of you had experience with using this kit http://store.summitracing.com/partd...908331+4294908282+4294925079+115&autoview=sku. I was looking at a P-S-T kit, but this one is a lot cheaper. thanks for your input,
    Ford Guy
  2. 1slow7t
    1slow7t Member
    Puerto Rico
    70 Maverick, 6 cyl/auto trans, soon to become a 351W w/pan fed C4.
    Can't tell you about the application, but I have an ES kit in one of my cars, and the suspension feels GREAT! One "very" important part when installing them is, lubrication. Use all the lube they send, and if possible, buy another tube, this to avoid any unwanted squeak noises while driving.(y)
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I wanted to replace all my rubber with poly, throughout the car.
    However I have been told by several folks, that may or may not know, that poly has only a fraction of the life of the rubber used in suspension parts.
    Is this true?
    I have seen poly objects in other applications fail quickly, is this the same poly used in suspension parts?
    Thanks
    Dave
  4. 1slow7t
    1slow7t Member
    Puerto Rico
    Well, this is their warranty statement, "Energy Suspension warrants its products to be free from defects in materials and workmanship for a period of two years from the date of purchase when used on passenger cars and light trucks", which is not a long enough period IMO. Mines have 2 years now, in a not daily driven car, but they are performing excelent.
  5. Dave B
    Also be careful with the Strut Rod bushings, they should stay rubber, some of the Poly bushings are too hard and can snap the strut rod.
    And as mentioned..lots-o-lube, I did my spring perches and their noisy.
  6. MikeG747
    MikeG747 Member
    Arkansas
    Me too Dave! Same thing (Noisy).:yup:
  7. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    Also, do I need to use a press to get the bushings on or can I do it myself with basic tools.
  8. 71gold
    ...street car...all rubber :yup:...my :2cents:
    only one i had a prob. with was the...idlerarm bushing :hmmm:
    ...frank...:bouncy:
  9. bmcdaniel
    bmcdaniel Senile Member
    The early Mustang rear spring bushings are larger in outside diameter then a Maverick's. Many years ago before Maverick poly kits were available I used an early Mustang kit. Had to use a lathe to turn down the rear bushings. Got tired of lubing the squeeky antisway bar bushings, went back to rubber there. The rubber parts available nowadays is better than what these cars came with. I think they are actually synthetic now.
  10. Maverick Man
    California
    get the ones pre done with zert fitting in them... then grease them... they don't make a sound ;)
    if anything the sway bars mounts will be noisy... that also if you don't grease them. and grease them alot with the right stuff.. which is way nasty!!
