Canton Oil Pan
Discussion in 'Technical' started by bhellickson, Jan 21, 2015.
  1. bhellickson
    bhellickson Member
    S. California
    1970 x2 71x2
  2. groberts101
    groberts101 Member
    Minneapolis, MN
    Looks pretty darn close to my road race style T-pan which is also 13 1/2" wide. Belly bar may be an issue(never checked as I'll just do a custom piece anyways).. and I do know for fact that the ends of the lower control arms need to be radiused and trimmed at their mounting point to have any clearance whatsoever. Even then.. engine rock during hard takeoffs/shifts might cause issues.
    Not saying is can't be done.. especially since I intend to do that same clearancing mod myself.. just that it won't be a bolt in deal, is all. If I can get my engine set back far enough with firewall mod's.. it'll actually turn into a bolt in deal for me after all.
  3. Bryant
    i had to notch mine to clear the lower control arm mounts.
    here some pics of it.
  4. baddad457
    I used a Milodon style 9 Qt (knock-off bought on Ebay) on mine and it fit without trimming anything. In addition, if you're using a main girdle, it'll need a kicked out rear wall to clear the girdle, didn't see that feature in that Canton link.
  5. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    I have a Moroso 20502 that looks a lot like your Canton. I had to have mine notched 2 1/2 inches to clear the lower control arm mounts. I have before and after pics if you want to see em.
  6. Bryant
    im not sure why the pics are not showing up. they are pics hosted on this site. when i look at the thread they were origanlly in they then appear in this thread. heres the thread that contains the pics. http://mmb.maverick.to/threads/my-347.65475/#post-667515
