cigarette lighter issues
Discussion in 'Technical' started by bradmosley, Jan 10, 2012.
  1. bradmosley
    bradmosley Member
    Pencsacola, FL
    73 Maverick
    A few days ago my cig lighter stopped working. checked the wire that plugs in the back and got no power. needed a new lighter(no ceramic hardly left in old one) so I installed a new one. Prety sure i did it wrong. I grounded the outside of the lighter to a good ground and ran the pwr to the acc on my fuse box. damn wire insulation burned up after testing the lighter. nothing else burned and no fuses blew, thank god. nothing happened when i simply plugged in the phone charger but as soon as the lighter is pushed in, damn thing gets hot immediately and sends wayyyyy too much juice through the wire. it is 18g....same as the factory blue w/red plug. Any ideas! all fuses are good. radio use to have yellow going to the lighter but i moved it to green so i dont destroy it somehow, stereo is aftermarket.
  2. mrbrooksy
    mrbrooksy Retread
    Motor city
    72 maverick,99 cherokee,2000 cherokee.80 suzuki ts 250 and a minivan
    maybe bad lighter,bad ground .make it a power outlet only and a non smoking car:D
  3. mercgt73
    mercgt73 Member
    What kind of new one? Like a $3 HELP products new one?
    So you connected it to the side of a current fuse? Are you sure it was the fused side and not the feed side?
    Sounds like a bad lighter or shorted housing. The center connector (positive) in the bottom of the lighter housing is supposed to be insulated from the housing (negative). Test it with another lighter, but install a fuse this time.
  4. darren
    Seen all kinds of new elements and housing bad out of the box.
  5. mojo
    I got to believe u had it hooked to the feed side, not fused side. According to my diagram the cigar orig wire is "blue w/white tracer and goes to the #1 fuse. If I remember it is a little more than 18ga.; heating elements pull a lot of current. Like mentioned nx time put a fuse in the circuit b4 any testing. I wud use some kind of voltage probe and make sure I had the fused b4 makin a perm connection.
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Hacking the harness is not helping your situation. The cig lighter needs a larger gauge wire, more like a #10. That's why the insulation burned off. The factory cig lighter wire was light blue/white. The blue/red is illumination and should only be hot when the lights are on.
  7. bmcdaniel
    bmcdaniel Senile Member
    That wire would handle 30 amps, almost the whole stock alternator output! A heating element only draws a large current when it's cold. As it warms up the resistance increases reducing the current draw. A properly working lighter will heat up quickly and not draw much current after the first few seconds.
  8. Jellob1afra
    Jellob1afra Member
    San Pedro, california
    1971 mercury comet
    im afraid to test my lighter.
  9. Dave B
    Do you have a fuse inline with the lighter? The fuse is there to protect the wire.
  10. Hinct
    Hinct New Member
    audi r8
    I also had a problem with my cigarette lighters. Than i change my cigarette lighter instantly and its working well now. Sometimes we fetch some problem it there is always a solution there.
  11. 71gold
    :Welcome:...:Handshake
