coolent leaking behind pulley...
Discussion in 'Technical' started by maverick656, Aug 20, 2013.
  1. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    So we just fixed an overflow problem recently, and now I have another problem. I drove it for about 2 days, and now its leaking coolant from what looks to be behind the fan. Maybe the water pump? From what I can see its below the water outlet/thermostat housing. Any suggestions?
  2. mojo
    If it is a housing with o ring it maybe worn out , or if gasket ck gasket.
    L
  3. Earl Branham
    Lugoff, SC
    Looks like the water pump seal is shot, and it is leaking from the weep hole. It is designed to do this to let you know you have a bad pump.
  4. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    It was the water pump. Replaced the pump, seems to run fine. Gonna drive it for awhile and see how it goes, thanks for the help!
  5. mojo
    Glad u got it worked out. I had both those issues in the past year. Replaced the wp last fall and the stat housing a few months ago.
